MiSTAR 555 Shop Floor CNC CMM
Compact 5-Axis CMM Built for the Shop Floor
The Mitutoyo MiSTAR 555 delivers high-accuracy, high-speed measurement right where machining happens. Designed for shop-floor use, it brings the precision of a lab-grade coordinate measuring machine into a rugged, compact frame that thrives in real-world production environments.
Country of Origin: Japan
The MiSTAR 555 offers a measuring range of 19.7 × 19.7 × 19.7 in (500 × 500 × 500 mm) with accuracy down to ±0.00016 in (±4 µm) at 68°F (20°C). Built on a fixed bridge structure with lightweight ceramic guideways, it maintains thermal stability up to 104°F (40°C). Air bearings on all axes ensure smooth motion, while Mitutoyo’s U-MAP software and optional scanning probes make it ready for complex 3D inspection tasks right on the production floor.
| Specification | Detail |
| Measuring Range (X × Y × Z) | 19.7 × 19.7 × 19.7 in (500 × 500 × 500 mm) |
| Accuracy (E0, at 68°F / 20°C) | ±0.00016 in (±4 µm) |
| Repeatability (R0) | ±0.00008 in (±2 µm) |
| Drive System | Air Bearing on All Axes / Linear Motor Drive |
| Thermal Compensation Range | 59–104°F (15–40°C) |
| Maximum Table Load | 330 lb (150 kg) |
| Probing System | Mitutoyo MTP200 / Renishaw SP25 optional |
| Software | MiCAT Planner / MCOSMOS / U-MAP |
| Machine Weight | ≈ 2,200 lb (1,000 kg) |
| Power Requirements | 100–240 V AC, 50/60 Hz |
Next Level Inspection
Blurb about the importance of metrology and inspection in your shop or classroom that highlights Mitutoyo's commitment to quality, precision, and excellence. Available for custom order today!
