Horizontal Dial Test Indicator
Product Details
Mitutoyo’s anti-magnetic lever indicator (dial test indicator, DTI) is built for precision alignment on machine tools and more. Designed to auto-adjust to the measuring direction on contact, it delivers smooth, accurate readings with minimal friction—thanks to its jewelled movement.
- Easy and accurate measurement of narrow or recessed areas, plus inside and outside diameters that dial indicators cannot access
- One-piece bezel and crystal design with O-ring provide resistance to water and dust
- Glare-free flat crystal face with a scratch-resistant coating
- Standard carbide contact point for durability
- Anti-magnetic for interference-free operation
#01mm-8mm-209mm-FullSet
- Graduation: .0005 in
- Range: 0-0.03 in
- Accuracy: .0005 in
- Dial Reading: 0-15-0
- Contact Point: .079 in
- Length: 33.9 mm
- Includes: Indicator, Inch Holding Bar, Swivel Clamp, Knurled Clamp Ring, Stems, Contact Points
#01mm-8mm-209mm-BasicSet
- Range: 0-0.03 in
- Length: 33.9 mm
- Includes: Indicator, Knurled Clamp Ring, Stems, .079” Contact Point
#0001in-008in-15mm-FullSet
- Graduation: .0001 in
- Range: 0-.008 in
- Accuracy: .0001 in
- Dial Reading: 0-4-0
- Length: 15 mm
#0001in-008in-15mm-BasicSet
- Range: 0-.008 in
- Length: 15 mm
#0005in-03in-199mm-FullSet
- Range: 0-0.03 in
- Length: 19.9 mm
#0005in-03in-199mm-BasicSet
- Range: 0-0.03 in
- Length: 19.9 mm
Sale price$159.72
Regular price$168.00 (/)
