AL600P IGE Wire EDM
Precision and Innovation in Wire-Cut EDM
Exceptional Precision: The AL600P IGE is equipped with Sodick’s patented i Groove mechanism, offering unparalleled accuracy in wire rotation. This feature ensures consistent use of new wire surfaces during machining, significantly improving the surface finish and stability when working on thick plates.
Cutting-Edge Technology: With features like advanced “Step-cut” machining for shapes with varying thickness, and a maintenance-free linear motor drive, the AL600P IGE provides high-speed, precision machining with minimal wear, thanks to its non-contact system. The built-in thermal displacement correction ensures precise operation even in challenging temperature environments.
Country of Origin: Japan
WIRE EDM'S NEW GROOVE
Introducing the world’s first wire rotation system, the 'i Groove.' This game-changer ensures super precise cuts by minimizing pitch error, making it perfect for progressive press dies. Backed by our own advanced tech, it delivers top-notch performance every time.
41.34" x 27.95" / 1050mm x 710mm
23.62" / 600mm
23.62" / 600mm
15.75" / 400mm
13.78" / 350mm
5.91" x 5.91" / 150mm x 150mm
±25° (Plate Thickness 5.12" / 130mm)
31.50" x 22.44" x 13.39" (during flushing machining) / 800mm x 570mm x 340mm
31.50" x 22.44" x 11.02" (during submerged machining) / 800mm x 570mm x 280mm
2204.62 lbs / 1000kg
Ø0.002" – Ø0.012" / Ø0.05mm – Ø0.30mm
3-23N (remains the same)
16.54 in/sec / 420mm/sec
39.17" / 995mm
101.38" x 116.54" x 92.32" / 2575mm x 2960mm x 2345mm
10,141.26 lbs / 4600kg
Why Choose Sodick?
Pushing the Boundaries of Wire EDM.
Sodick machines combine unparalleled precision with fast cutting speeds, allowing machinists to achieve high-quality results without sacrificing efficiency, even on the most demanding jobs.
Sodick offers a wide range of machines that cater to industries such as aerospace, automotive, and mold-making, with customizable options to suit both high-precision and high-speed production requirements.
Sodick’s machines are engineered with maintenance-free linear motors, minimizing downtime and ensuring that your shop runs smoothly with fewer interruptions for repairs or adjustments.
With over 40 years of industry experience, Sodick’s vertically integrated production process ensures the highest level of quality control at every step—from R&D to final machine assembly—giving machinists confidence in their investment.
Sodick has a strong global presence, offering industry-leading service and support, backed by expert teams to provide local assistance and training wherever your shop is located.
