Flat rate shipping applied at checkout. If actual rate varies, the final order amount will be adjusted.
Sale price$12,499.65 Regular price$12,999.00
Feature Highlights
Suction Unit
By utilizing 3 bypass motors this unit allows the operator to have full control over the intake performance. Depureco also places the motors in a sturdy casing with an insulating sponge to maintain an ultra-low noise level.
Inlet
Depureco's intake system uses a specialized nozzle and filtering grid to efficiently separate solid particles from liquids. After separation, the liquid is stored in a large tank, perfectly prepared for safe reintegration with your machinery.
Filtering Element
Depureco's advanced filtration features a PPL filter for 150µ efficiency and an optional TNT filter for 100µ, ensuring even the finest particles are captured. This results in cleaner, reusable liquid. Filters are designed for easy washing and reuse.
Discharge System
Depureco integrates a submerged pump within the tank to guarantee effective emptying. The intelligent design includes a level sensor that halts operations when the tank is full or empty, optimizing safety and efficiency.
RAM 280 MP
A must-have sump industrial vacuum for oil and chips.
Motor Type
By-pass
Power
5.2 hp (3.9 kW)
Voltage / Frequency
230 V / 50–60 Hz
Vacuum (Continuous)
100 inH2O (250 mbar)
Maximum Air Flow
336 cfm (570 m³/h)
Suction Inlet
2 in Ø (50 mm)
Noise Level
72 dB(A)
Liquids Capacity
74.0 gal (280 L)
Solids Capacity
10.6 gal (40 L)
Liquid Discharge Rate
21.1 gal/min (80 L/min)
Collection System
Steel container
Liquid Discharge System
Discharge pump
Dimensions
27.6 × 57.1 in (700 × 1450 mm)
Height
52.0 in (1,320 mm)
Weight
333 lb (151 kg)
Solid Separation
Basket grid
Forklift Support
Included
Primary Filter Type
Bag
Filter Media
Polypropylene 150 μ
Additional Filter
Oil filter
Show more Show fewer
Safety data sheets available upon request.
