TRIMILL VS 1614 5-Axis Milling Center
5-Axis Gantry Milling with Box-in-Box Design
The TRIMILL VS 1614 is a 5-axis gantry milling machine featuring a rigid closed crossbar “Box-in-Box” design and a tilting-rotary table for full-spectrum contour machining. Built for power, accuracy, and speed, it handles complex molds and aerospace components with ease.
Country of Origin: Czech Republic
Customize Your CNC
Power, Rigidity, Reach
The VS 1614 combines a 1,600 × 1,400 × 800 mm working envelope with a tilting-rotary table Ø1,200 mm that supports 2,500 kg workpieces. Equipped with optional spindles up to 40 kW and 14,000 rpm or high-speed 24,000 rpm heads, it delivers flexibility for both roughing and finishing in one setup.
14,000 rpm / 24,000 rpm optional
43–54 hp (32–40 kW)
Heidenhain / Siemens (5-axis with direct measuring)
63 × 55 × 31 in (1,600 × 1,400 × 800 mm)
63 in X / 55 in Y / 31 in Z (1,600 / 1,400 / 800 mm)
Ø47 in (1,200 mm) tilting-rotary table
5,512 lb (2,500 kg) including fixture and workpiece
1,180 ipm (30,000 mm/min)
Value217 × 165 × 149 in (5,500 × 4,200 × 3,800 mm), approx. 70,548 lb (32,000 kg)
Box-in-Box gantry design, torque-motor table, direct-axis measuring system, vibration monitoring
Why Choose Trimill, a YCM Alliance Brand?
Precision, Power, and Simplicity in One Package.
Built in the Czech Republic for global precision manufacturing.
Ships as one piece for quick installation and alignment.
Ergonomic layout gives clear access to the working area.
Used worldwide in mold, die, and aerospace industries.
Service and support you can count on wherever you’re located.
