SolidCAM
Powerful CAM for Professional Shops. SolidCAM is the go-to integrated CAM solution for machinists, job shops, and production facilities worldwide. Compatible with SOLIDWORKS and Autodesk Inventor, it delivers everything from 2.5D milling to complex multi‑axis and iMachining operations.
- Supercharge CNC machining with iMachining
- Cut cycle times by 70%
- Extend tool life up to 5X
- Automatically optimize feeds & speeds with the iMachining Technology Wizard
Best-in-Class CAM Solution for Professional Manufacturing
From high-mix job shops to full production environments, SolidCAM delivers a powerful, fully integrated CAM solution inside SOLIDWORKS or Autodesk Inventor. It supports 2.5D, 3D, HSS, HSM, iMachining, and full multi-axis capabilities—making it ideal for nearly any machining operation.
With post processors for thousands of machine tools and unmatched support for complex toolpaths and automation, SolidCAM is trusted by some of the world’s most advanced manufacturers. Commercial licenses include full access to the SolidCAM support network and continual updates.
System Requirements
Desktop Workstations
| Component | Minimum | Mid-Range | High-End |
| Processor (CPU) | Intel Core i5-13600K / AMD Ryzen 3 4100 | Intel Core i7-13700K / AMD Ryzen 5 7600X | Intel Core i9-13900K / AMD Ryzen 7 7700X |
| Video Card (GPU) | NVIDIA T1000* | NVIDIA Quadro P2200* | NVIDIA Quadro RTX A6000* |
| Memory (RAM) | 16GB DDR4 | 32GB DDR4 | 64GB DDR4 |
| Storage | M.2 NVMe 256GB SSD | M.2 NVMe 512GB SSD | M.2 NVMe 2TB SSD |
| Operating System | Windows 11 Pro | Windows 11 Pro | Windows 11 Pro |
* Equivalent models supported.
Note: These specifications do not include a motherboard, power supply, optical drive, keyboard, mouse, or monitor.
Portable Laptops
| Category | Recommended Model |
| Lightweight Portable Ultrabook | ThinkPad P15v Gen 2 with Core™ i9-13 and NVIDIA® RTX™ A2000* |
| High-End Workstation Laptop | HP ZBook Studio G8 with NVIDIA Quadro RTX3000* |
Important: SolidCAM is an add-in and requires SOLIDWORKS or Autodesk Inventor to be installed on your system.
Modules & Capabilities
- 2.5D Milling, 3D Milling, and HSM
- Turning and Advanced Mill-Turn
- iMachining for time-saving toolpaths
- Simultaneous 4- & 5-Axis Machining
- Probing, Wire EDM, and Additive support
- Compatible with thousands of machine tool post processors
Why Choose SolidCAM?
Designed for Makers. Trusted by Machinists.
Seamless CAD Integration
SolidCAM runs directly inside SOLIDWORKS or Inventor, so you stay in your design environment while programming your parts. No jumping between systems—what you design is what you machine.
One Software for Everything
Milling, turning, mill-turn, 5-axis, Swiss-type—it’s all built into one powerful platform. Whether you’re cutting basic parts or complex 5-axis jobs, SolidCAM keeps it simple.
Powerful iMachining Technology
SolidCAM’s exclusive iMachining gets you faster cycle times, longer tool life, and better material removal rates. It’s like having a CNC expert built right into your software.
From Hobby Shop to Production Floor
SolidCAM scales with you. The free Maker Version is perfect for projects and learning, and when it’s time to go pro, the same tools power full commercial machines.
Global Support, Local Know-How
Backed by worldwide training, support, and an active TITANS of CNC community, SolidCAM helps you solve problems fast and keep your machines cutting.
Next-Level Learning!
SolidCAM Maker Version
With the free SolidCAM Maker Version, hobbyists, students, and makers can turn their designs into real parts using the same CAM software trusted by manufacturers worldwide.
SolidCAM’s core strategy is tight integration within the leading 3D CAD systems, SOLIDWORKS and Autodesk Inventor. This approach has driven major growth and established SolidCAM as the leader in integrated CAM, and one of the most powerful CAM systems available.
