WorkFlow Compact Pallet Automation for High-Mix CNC Production
Built for Real CNC Production Floors
HENNIG WorkFlow is a modular pallet handling system designed to keep CNC machines running efficiently by organizing pallets, fixtures, and parts at the machine. Built to integrate directly with vertical machining centers, WorkFlow supports faster part staging and changeovers without forcing changes to existing shop workflows.
Designed for real-world production, WorkFlow helps shops manage multiple jobs, fixtures, and part sizes with a structured, repeatable system. Its modular layout scales from single-machine setups to multi-machine cells, giving operators full control over loading, scheduling, and setup while maintaining consistent, predictable machine operation.
Country of Origin: USA
Pallet Handling, Built for CNC Shops
HENNIG WorkFlow keeps pallets, fixtures, and parts staged and accessible where they belong. The result is fewer interruptions, faster changeovers, and consistent machine utilization during extended production and lights-out operation.
Quick Palette Change
  • Fast pallet swaps keep spindles cutting
  • Less downtime between jobs
  • Repeatable, reliable setups
Space Saving, Compact Design
  • Small footprint for tight shops
  • Installs cleanly next to the machine
  • More output without more floor space
Next Level Organization
  • Organized pallet and fixture storage
  • Clear job and part identification
  • Built for high-mix production
True Lights-Out Machining
  • Supports long unattended runs
  • Reliable pallet access for long cycles
  • Ready for nights and weekends
Why Choose Hennig?
