X7™ Industrial Composite 3D Printer
Turnkey Industrial Carbon Fiber 3D Printed Parts
The Markforged® X7™ CFR industrial carbon fiber 3D printer combines precision-built hardware, advanced sensors, and leading-edge software to deliver accurate parts repeatably. It features a reinforced, precision-machined gantry and a precision ground print bed that can be removed and replaced with 10 μm repeatability. Each piece of hardware in the filament extrusion system — from the nozzles to the extruder hobs — is optimized to resist wear from micro carbon fiber filled nylon filaments and maintain print quality over thousands of hours. Out of material sensors ensure that you’re always printing, while a scanning laser on the printhead enables the printer to dynamically adjust the first layers of a print to achieve perfect bed adhesion and inspect parts for accuracy after printing.
The X7™ has a 3rd-generation fiber reinforcement system that enables you to lay down continuous fiber into parts. Markforged composite printers are uniquely capable of printing four types of continuous fiber reinforced parts.
Country of Origin: Canada
Specification | Details |
Printing Process | Continuous Fiber Reinforcement (CFR) |
Z Layer Resolution | 0.002" - 0.01" (50 μm - 250 μm) |
Printing Media | Composite Base Filaments, Continuous Fibers |
Internal Part Geometry | Closed Cell Infill with Continuous Fiber Reinforcement |
Print Bed | Precision Ground Composite |
Physical Dimensions | Width: 23.0" (584 mm), Depth: 19.0" (483 mm), Height: 36.0" (914 mm) |
Weight | 106 lbs (48 kg) |
Build Volume | Width: 13.0" (330 mm), Depth: 10.6" (270 mm), Height: 7.9" (200 mm) |
Game Changer
Print parts in hours, not weeks. The power of Continuous Carbon Fiber at your fingertips.
Onyx®
Onyx® — the flagship Composite Base material — is a micro carbon fiber filled nylon that yields accurate parts with near flawless surface finish. Few materials have the versatility of Onyx; it offers high strength, toughness, and chemical resistance when printed alone, and can be reinforced with Continuous Fibers to yield aluminum-strength parts. Today, there are more than a million Onyx parts in the field transforming manufacturing.
Aramid Fiber (Kevlar®)
Aramid Fiber is a Kevlar® based, specialized Continuous Fiber known for its energy absorption and extreme toughness. When laid into Onyx or another Composite Base material, it yields impact-resistant parts that are nearly immune to catastrophic failure (fracture). It’s perfect for use in parts that are in demanding environments or are subject to repetitive loading.
Onyx FR™
Onyx FR is a flame-retardant variant of Onyx designed for use in applications where parts must be non-flammable. The material earned a UL Blue Card, and is considered V-0 (self extinguishing) at thicknesses greater than or equal to 3mm. It can be reinforced with any Continuous Fiber and is compatible with industrial composite 3D printers.
Onyx ESD™
Onyx ESD is a static-dissipative chopped carbon fiber nylon material, precision-engineered for a tight range of surface resistance. Onyx ESD meets ESD-safe requirements of the most stringent manufacturers, while offering the same industry-leading print quality of Onyx. Onyx ESD is stronger and stiffer than Onyx, with the same near perfect surface finish, making it suitable for advanced manufacturing applications from electronics assembly to industrial robotics and process automation.
Carbon Fiber
Carbon Fiber is Markforged’s unique, ultra-high-strength Continuous Fiber — when laid into a Composite Base material like Onyx, it can yield parts as strong as 6061-T6 Aluminum. It’s extremely stiff and strong, and can be automatically laid down in a wide variety of geometries by Markforged 3D printers. A special Carbon Fiber variant is compatible with ULTEM™ 9085 Filament.
Precise PLA
Precise PLA is our easy-to-print plastic for precision concept modeling and validation. Based on the most common 3D printing prototyping material, Precise PLA 3D prints without warping and comes in a variety of colors. Best of all, it’s affordable. So you can use as much as you need to fine-tune your designs before implementation.
Nylon
Nylon is an unfilled thermoplastic. It’s a non-abrasive material that is great for ergonomic surfaces and workholding for pieces that are easily marred. It can be painted or dyed.
Smooth TPU 95A
Smooth TPU 95A is a rubber-like material that when used with Markforged composite printers offers product developers and manufacturers the ability to create flexible, impact-absorbent parts on demand.
Carbon Fiber FR
Carbon Fiber FR is a flame-retardant variant of Markforged’s unique, ultra-high-strength Continuous Carbon Fiber — when used to reinforce a Composite Base material like Onyx FR, it can yield parts as strong as 6061-T6 Aluminum. It’s extremely stiff and strong, and can be precisely laid down in a wide variety of geometries. Programmatically trace curved features, reinforce holes, and mimic unidirectional fiber layups — all within a few clicks.
Fiberglass
Fiberglass is Markforged’s entry-level Continuous Fiber —a material capable of yielding parts 10x stronger than ABS when laid into a Composite Base material like Onyx. Fiberglass is the flagship material of the Onyx Pro and X5 and printable on the Mark Two and X7, providing a more affordable alternative to Carbon Fiber.
HSHT Fiberglass
High Strength High Temperature (HSHT) Fiberglass is defined by two characteristics: high strength (nearly equal to 6061-T6 Aluminum) and strength in high temperatures. Though not as stiff as Continuous Carbon Fiber, Onyx parts reinforced with HSHT are strong at both low and high temperatures. As a result, HSHT reinforcement is best used for parts in high-temperature environments like molds, autoclaves, and others.
Simple and safe workflow designed for any business.
Why Choose Markforged?
Unlock Next-Level Precision and Innovation in Your Shop with 3D Printing.
Innovative Technologies
Markforged's innovations like carbon fiber reinforcement, integrated laser scanning quality control, and part simulation software evolved 3D printing from prototyping to the factory floor.
Strong, Precise Parts
Precision engineering printing hardware, advanced composite materials and carbon fiber reinforcement enable Markforged 3D printers to generate accurate, industrial-strength parts with beautiful surface finish time after time.
"Just Press Print" Simplicity
Markforged tightly integrates 3D printing hardware, materials, and intuitive software, making printing industrial-quality parts easy for non-experts on the shop floor.
Industrial Reliability
Markforged's industrial 3D printers are famed for their reliability, which is why over 5,000 manufacturing facilities across the world rely on Markforged to keep lines running and customers satisfied.
Scalability and Flexibility
The Digital Forge is designed to scale, catering to both small businesses and large enterprises. Whether you need one printer or a fleet, the platform scales to meet your production demands without the need for extensive retooling or setup changes.
