FX10™ Industrial Composite 3D Printer
Next Generation Industrial Composite 3D Printer
FX10™ is Markforged’s next generation industrial composite 3D printer — the result of years of engineering innovation and technological advancement. Built on the success of the Markforged® X7™, its sole purpose is to deliver strong, accurate parts every print. FX10™ features a new modular architecture that’s designed for upgradability and print head-mounted optical sensors that can verify dimensional accuracy of parts and assess device health and performance. It utilizes automatic calibration and material changeover, yielding a simple, low-touch user experience that mitigates the need for dedicated operators. Markforged software controls every aspect of FX10™ — so users can quickly go from CAD to print, share parts across their organization, and monitor fleet performance from a central location. FX10™ is the versatile tool that supercharges your manufacturing productivity and profitability.
Country of Origin: Canada
Specification | Details |
Printing Process | Fused Filament Fabrication, Continuous Fiber Reinforcement |
Z Layer Resolution | 0.005" to 0.01" (125µm to 250µm) |
Printing Media | Polymer Filament, Continuous Fibers |
Internal Part Geometry | Closed Cell Infill with Continuous Fiber Reinforcement |
Print Bed | Precision Machined Aluminum |
Physical Dimensions | Width: 29.92" (760mm), Depth: 25.20" (640mm), Height: 47.24" (1200mm) |
Weight | 240 lbs (109kg) |
Build Volume | Width: 14.76" (375mm), Depth: 11.81" (300mm), Height: 11.81" (300mm) |
Supercharge Your Manufacturing
Unlock strong parts on demand. Print the right part every time. Drive ROI fast, then scale.
Onyx® (Plastic)
Onyx® — the flagship Composite Base material — is a micro carbon fiber filled nylon that yields accurate parts with near flawless surface finish. Few materials have the versatility of Onyx; it offers high strength, toughness, and chemical resistance when printed alone, and can be reinforced with Continuous Fibers to yield aluminum-strength parts. Today, there are more than a million Onyx parts in the field transforming manufacturing.
Carbon Fiber
Carbon Fiber is Markforged’s unique, ultra-high-strength Continuous Fiber — when laid into a Composite Base material like Onyx, it can yield parts as strong as 6061-T6 Aluminum. It’s extremely stiff and strong, and can be automatically laid down in a wide variety of geometries by Markforged 3D printers. A special Carbon Fiber variant is compatible with ULTEM™ 9085 Filament.
Simple and safe workflow designed for any business.
Why Choose Markforged?
Unlock Next-Level Precision and Innovation in Your Shop with 3D Printing.
Innovative Technologies
Markforged's innovations like carbon fiber reinforcement, integrated laser scanning quality control, and part simulation software evolved 3D printing from prototyping to the factory floor.
Strong, Precise Parts
Precision engineering printing hardware, advanced composite materials and carbon fiber reinforcement enable Markforged 3D printers to generate accurate, industrial-strength parts with beautiful surface finish time after time.
"Just Press Print" Simplicity
Markforged tightly integrates 3D printing hardware, materials, and intuitive software, making printing industrial-quality parts easy for non-experts on the shop floor.
Industrial Reliability
Markforged's industrial 3D printers are famed for their reliability, which is why over 5,000 manufacturing facilities across the world rely on Markforged to keep lines running and customers satisfied.
Scalability and Flexibility
The Digital Forge is designed to scale, catering to both small businesses and large enterprises. Whether you need one printer or a fleet, the platform scales to meet your production demands without the need for extensive retooling or setup changes.
