Metal X | Metal 3D Printer
Revolutionizing Metal 3D Printing
The Markforged Metal X is changing the game in metal 3D printing with its innovative approach that mixes metal powder with a plastic matrix. This not only ramps up safety but also makes it a breeze to set up in regular shops without needing hefty upgrades. It's kitted out with all the bells and whistles like a precision-engineered gantry, a heated chamber, and top-notch extrusion hardware, all designed to crank out tough and precise parts easily. Plus, it's super user-friendly with straightforward maintenance and quick swaps for consumables.
The Metal X System's Wash and Sinter machines play a key role in knocking out top-notch parts, ensuring everything is cleaned up and fused just right.
Country of Origin: Canada
Specification | Details |
Printing Process | Metal FFF |
Z Layer Resolution | 0.0033" - 0.0067" (85 μm - 170 μm Post-Sinter) |
Printing Media | Bound Powder Filament |
Internal Part Geometry | Closed Cell Infill (Triangular) or Solid Parts |
Print Bed | Heated, Auto Leveling, Replaceable Print Sheets |
Physical Dimensions | 22.64" x 18.39" x 44.09" (575 mm x 467 mm x 1120 mm) |
Weight | 165 lbs (75 kg) |
Build Volume | 11.81" x 8.66" x 7.09" (300 mm x 220 mm x 180 mm) |
Next Day Metal Parts
From design to fully functional metal parts in as few as 28 hours.
From stainless steel to copper, choose from a wide range of strong, durable, and capable materials.
Inconel 625
Inconel 625 is a nickel-chromium based superalloy that is extremely resistant to corrosion and strong at high temperatures. It’s easy to print, enabling you to fabricate functional prototypes and end-use parts designed for harsh environments. Markforged Inconel 625 meets chemical requirements of ASTM B443 and maintains a UTS of 500 MPa at 600 ºC.
17-4PH Stainless Steel
17-4PH Stainless Steel is a multipurpose steel used for industrial applications. Heat-treatable to 36 HRC and possessing 95% wrought strength, Markforged 17-4PH enables you to print high-strength, robust metal parts for a wide variety of applications.
A2 and D2 Tool Steel
A2 and D2 are cold work tool steels defined by their extremely high hardness after heat treatment. A2 tool steel is often regarded as a “universal” cold work steel, offering a combination of good wear resistance and high toughness. D2 tool steel is harder and more wear-resistant, but less tough. Both can be used for cutting and forming tools, or other applications where high hardness are valued.
H13 Tool Steel
Harder than 17-4 PH Stainless Steel and capable of maintaining material properties at high temperatures, H13 tool steel is an extremely versatile material to work with. Markforged H13 can be heat treated to 45 HRC with a UTS of 1680 MPa, and is used by Markforged customers for tool bodies, brazing fixtures, and other parts where hardness or heat resistance are required.
Copper
Pure copper conducts heat and electricity far better than traditional metals. Markforged Copper possesses better conductivity characteristics than alloyed copper that can be printed on DMLS machines. Unlike conventional fabrication processes which are extremely labor intensive and expensive, Markforged Copper is extremely simple to 3D print.
Simple and safe workflow designed for any business.
Why Choose Markforged?
Unlock Next-Level Precision and Innovation in Your Shop with 3D Printing.
Innovative Technologies
Markforged is at the forefront of 3D printing technology, utilizing processes such as continuous fiber fabrication and unique techniques like their ADAM (Atomic Diffusion Additive Manufacturing) for metal printing. These technologies enable the creation of parts that are both lighter and stronger than those made with conventional manufacturing methods.
Integrated Software and Hardware Platform
Markforged offers a unique ecosystem called the Digital Forge, which seamlessly integrates software, materials, and printers. This integration allows for continuous improvement of parts and processes over time, making it an adaptive and smart solution for manufacturing needs.
Scalability and Flexibility
The Digital Forge is designed to scale, catering to both small businesses and large enterprises. Whether you need one printer or a fleet, the platform scales to meet your production demands without the need for extensive retooling or setup changes.
Wide Range of Materials
Markforged provides a diverse range of materials, including metals, composites, and continuous fibers, which are designed to meet various industrial applications. This versatility enables manufacturers to create high-strength parts that can replace traditional manufacturing materials like aluminum.
Precision and Quality
The precision of Markforged printers is unmatched, allowing for the production of parts with exceptional accuracy and surface finish. This level of quality ensures that components are produced with the reliability needed for crucial industrial applications.
