Onyx Pro | Desktop Composite 3D Printer
Precision-Built So You Can 3D Print Precise Parts
The Onyx Pro is an advanced professional 3D printer – built around the Continuous Fiber Reinforcement (CFR) process to reliably produce strong parts for you. It’s built around an aluminum unibody frame that delivers high accuracy and repeatability. A hardened extrusion system enables the Onyx Pro to print Onyx — a micro carbon fiber filled nylon filament that destroys traditional extrusion systems — reliably over thousands of print hours. The machine is built to be easy to operate and maintain — from easy-to-reach wear components (like nozzles and feed tubes) to usability focused features like the print bed, which can be removed and replaced with 10 μm repeatability.
In addition to more common FFF features, the Onyx has a 2nd-generation fiber reinforcement system that enables you to lay down continuous Fiberglass into parts. Markforged composite printers are capable of printing continuous fiber reinforced parts, which can replace machined aluminum parts in application.
Country of Origin: Canada
Specification | Details |
Printing Process | Continuous Fiber Reinforcement (CFR) |
Z Layer Resolution | 0.004" - 0.008" (100 μm - 200 μm) |
Printing Media | Composite Base Filaments, Continuous Fibers |
Internal Part Geometry | Closed Cell Infill with Continuous Fiber Reinforcement |
Print Bed | Precision Ground Composite |
Physical Dimensions | Width: 23.0" (584 mm), Depth: 13.0" (330 mm), Height: 14.0" (355 mm) |
Weight | 35 lbs (16 kg) |
Build Volume | Width: 12.6" (320 mm), Depth: 5.2" (132 mm), Height: 6.1" (154 mm) |
3D-Printed Precision
Leverage the power of Continuous Fiberglass reinforcement to print parts 10x stronger than plastic.
Print Continuous Fiberglass-reinforced parts 10x stronger than ABS — extremely durable and capable of replacing some machined aluminum parts.
This professional 3D printer features a unibody aluminum chassis and precision-machined components to deliver lights-out reliability over thousands of print hours.
Print precise parts with near flawless surface finish thanks to Onyx, Markforged’s extremely versatile micro carbon fiber filled nylon material.
Onyx® (Plastic)
Onyx® — the flagship Composite Base material — is a micro carbon fiber filled nylon that yields accurate parts with near flawless surface finish. Few materials have the versatility of Onyx; it offers high strength, toughness, and chemical resistance when printed alone, and can be reinforced with Continuous Fibers to yield aluminum-strength parts. Today, there are more than a million Onyx parts in the field transforming manufacturing.
Precise PLA
Precise PLA is our easy-to-print plastic for precision concept modeling and validation. Based on the most common 3D printing prototyping material, Precise PLA 3D prints without warping and comes in a variety of colors. Best of all, it’s affordable. So you can use as much as you need to fine-tune your designs before implementation.
Smooth TPU 95A
Smooth TPU 95A is a rubber-like material that when used with Markforged composite printers offers product developers and manufacturers the ability to create flexible, impact-absorbent parts on demand.
Fiberglass
Fiberglass is Markforged’s entry-level Continuous Fiber —a material capable of yielding parts 10x stronger than ABS when laid into a Composite Base material like Onyx. Fiberglass is the flagship material of the Onyx Pro and X5 and printable on the Mark Two and X7, providing a more affordable alternative to Carbon Fiber.
Simple and safe workflow designed for any business.
Why Choose Markforged?
Unlock Next-Level Precision and Innovation in Your Shop with 3D Printing.
Innovative Technologies
Markforged is at the forefront of 3D printing technology, utilizing processes such as continuous fiber fabrication and unique techniques like their ADAM (Atomic Diffusion Additive Manufacturing) for metal printing. These technologies enable the creation of parts that are both lighter and stronger than those made with conventional manufacturing methods.
Integrated Software and Hardware Platform
Markforged offers a unique ecosystem called the Digital Forge, which seamlessly integrates software, materials, and printers. This integration allows for continuous improvement of parts and processes over time, making it an adaptive and smart solution for manufacturing needs.
Scalability and Flexibility
The Digital Forge is designed to scale, catering to both small businesses and large enterprises. Whether you need one printer or a fleet, the platform scales to meet your production demands without the need for extensive retooling or setup changes.
Wide Range of Materials
Markforged provides a diverse range of materials, including metals, composites, and continuous fibers, which are designed to meet various industrial applications. This versatility enables manufacturers to create high-strength parts that can replace traditional manufacturing materials like aluminum.
Precision and Quality
The precision of Markforged printers is unmatched, allowing for the production of parts with exceptional accuracy and surface finish. This level of quality ensures that components are produced with the reliability needed for crucial industrial applications.
