SKU: MF55-F002
Replacement 2nd Stage Demister Element
Sale price$210.00
Mist Collector Model: MF-550
Installs Quickly
Easy to Use
Clear the Air
MF 550
Airflow500–600 cfm
Enclosure250 ft³
Motor0.75 hp
Max Temp125°F (50°C)
pH Limits5.8–9.8
Weight65 lb (HEPA +10 lb)
Dimensions15 × 15 × 26 in
Inlet6″ ø
Sound66 dB(A)
MF 560
Airflow500–600 cfm
Enclosure250 ft³
Motor0.75 hp
pH Limits5.8–9.8
Weight96 lb (HEPA +26 lb)
Dimensions20 × 20 × 28 in
Inlet6″ ø
Sound66 dB(A)
MF 1050
Airflow900–1,100 cfm
Enclosure450 ft³
Motor1.5 hp
pH Limits5.8–9.8
Weight98 lb (HEPA +26 lb)
Inlet8″ ø
Sound68 dB(A)
MF 1950
Airflow1,900–2,000 cfm
Enclosure2,000 ft³
Motor3 hp
pH Limits5.8–9.8
Weight270 lb (HEPA +54 lb)
Dimensions25 × 25 × 36 in
Inlet12″ ø
Sound72 dB(A)
Revolution is in the Air
Why Choose AEROEX?
