NOW SHIPPING WORLDWIDE!
Flat rate shipping applied at checkout for domestic orders. If actual rate varies, the final order amount will be adjusted.
For international orders, please contact us for a quote before placing an order.
SKU: MF55-0115
Mist-Fit MF-550 Mist Collector
Sale price$4,500.00
Voltage (Amps): 115/1/60
Installs Quickly
Easy to Use
Clear the Air
Separation Stages
Multi-stage separation process effectively eliminates a wide range of airborne contaminants, ensuring not only the longevity and efficiency of machinery but also promoting a healthier workplace environment. By reducing exposure to harmful particulates, it enhances air quality and safety for all workspace occupants.
Stage 1
The innovative 1st stage Mechanical Element separates up to 90% of the oil mist and swarf, with smooth metal surfaces for quick fluid drainage back to the sump.
Stage 2
The 2nd stage Demister Element supports the 1st stage to ensure up to 95% of the mist and swarf are removed with washable filters.
Stage 3
The 3rd stage Fiber Bed mist filter is depth loading and captures small mist particles. With a filter rating of MERV 15, it can be used without a HEPA filter on most applications, with a typical life of 1-3 years.
Stage 4 (Optional)
HEPA Filter captures sub-micron mist, smoke, and bacteria. Efficiency is 95% @ 0.3 μm as standard, and optional 99.9% @ 0.3 μm, with a typical life of 2-4 years.
Stage 5 (Optional)
Pre-Filter Box is recommended for oil and heavy mist, extending filter life, particularly for Swiss screw machines.
MF 550
Airflow500–600 cfm
Enclosure250 ft³
Motor0.75 hp
Max Temp125°F (50°C)
pH Limits5.8–9.8
Weight65 lb (HEPA +10 lb)
Dimensions15 × 15 × 26 in
Inlet6″ ø
Sound66 dB(A)
MF 560
Airflow500–600 cfm
Enclosure250 ft³
Motor0.75 hp
pH Limits5.8–9.8
Weight96 lb (HEPA +26 lb)
Dimensions20 × 20 × 28 in
Inlet6″ ø
Sound66 dB(A)
MF 1050
Airflow900–1,100 cfm
Enclosure450 ft³
Motor1.5 hp
pH Limits5.8–9.8
Weight98 lb (HEPA +26 lb)
Inlet8″ ø
Sound68 dB(A)
MF 1950
Airflow1,900–2,000 cfm
Enclosure2,000 ft³
Motor3 hp
pH Limits5.8–9.8
Weight270 lb (HEPA +54 lb)
Dimensions25 × 25 × 36 in
Inlet12″ ø
Sound72 dB(A)
Machine Tool Enclosure Sizing Guide
When determining the sizing of mist collectors, several factors come into play. As a rule of thumb, we suggest multiplying the machine enclosure volume by a factor of 2-6 depending on the mist level, with a factor of 2 suitable for large machines of 1000 cubic feet and above.
Condition Multiplier (X) Formula
Light Mist 1 to 2 L x W x H x Multiplier = Required CFM
Moderate Mist 3 to 4 L x W x H x Multiplier = Required CFM
Heavy Mist / Smoke 4 to 6 L x W x H x Multiplier = Required CFM
Example: On a lathe with high-pressure coolant and an internal dimension of 5ft high X 6ft deep X 10ft long, the machine enclosure is 300 cubic feet—the calculation suggests an airflow requirement of approximately 900 CFM, when multiplied by a factor of 3.
Revolution is in the Air
Why Choose AEROEX?
