MX-330 PC10 5-Axis Vertical Machining Center
Compact 5-Axis Machining Center with PC10 Pallet Changer
The MX-330 brings 5-axis machining to shops of all sizes with a compact footprint and outstanding versatility. Designed for accuracy and repeatability, it enables single-setup machining of complex parts across aerospace, medical, and precision industries. Its rigid design and advanced control system make it a smart fit for both production and prototyping environments.
With the PC10 pallet changer system, shops gain true lights-out capability — continuous machining across multiple setups without operator intervention. Combined with a high-speed spindle and automatic tool changer, the MX-330 ensures maximum spindle uptime, efficiency, and productivity. This platform is a go-to solution for shops looking to expand their 5-axis capacity with automation-ready reliability.
Available in multiple configurations.
Country of Origin: Japan
The Matsuura MX-330 with the PC10 pallet changer takes 5-axis machining to the next level. Designed for lights-out production, the PC10 system allows continuous, unattended machining across multiple setups, maximizing spindle uptime and throughput. Combined with the MX-330’s high-speed spindle and generous tool capacity, this platform delivers unmatched efficiency for both high-mix, low-volume work and long production runs.
| Specification | Details |
| Standout Features | Compact design, large tool magazine option, automation-ready |
| Additional Axis | B-axis tilt ±125°, C-axis continuous 360° |
| Spindle Speed | 15,000 rpm |
| Spindle Power | 20 hp (15 kW) |
| Tool Taper | BT40 / HSK-A63 |
| Table Size | 13.8" diameter (350 mm) |
| Max Workpiece Weight | 176 lbs (80 kg) |
| Tool Changer Capacity | 30 tools (optional up to 90) |
| Control | FANUC 31i-MB Plus |
| Automation Capability | PC10 pallet changer system, full automation integration |
Compact Power, Big Results
The MX-330’s high-speed spindle delivers up to 15,000 rpm with 20 hp (15 kW) of power, handling tough materials and fine surface finishes with ease. Its ±125° B-axis and 360° C-axis provide true 5-axis flexibility, while tool capacity up to 90 tools supports long production runs. A compact footprint makes it perfect for small shops wanting to expand into 5-axis machining without sacrificing floor space.
Compact 5-Axis Design
15,000 rpm
20 hp (15 kW)
BT40 / HSK-A63
FANUC 31i-MB Plus
176 lbs (80 kg)
Optional pallet system, automation integration
Why Choose Matsuura?
Innovation that Drives Precision
Built in Japan with precision engineering and rigorous quality control.
Industry pioneer in multi-pallet and lights-out production systems.
Decades of proven uptime in aerospace, medical, and precision machining.
Integration of advanced spindles, controls, and monitoring systems.
Strong distributor and service network ensures long-term partnership.
