Machine Control Wiring Kit for MF-1050
Aeroex Technologies machine control wiring kits provide the electrical components needed to integrate your Mist-Fit mist collector with compatible CNC machines.
Choose the appropriate voltage and control configuration for your machine tool and to view the kit's contents.
Installs Quickly
Easy to Use
Clear the Air
MF 550
| Airflow | 500–600 cfm |
| Enclosure | 250 ft³ |
| Motor | 0.75 hp |
| Max Temp | 125°F (50°C) |
| pH Limits | 5.8–9.8 |
| Inlet | 6″ ø |
| Sound | 66 dB(A) |
MF 560
| Motor | 0.75 hp |
| Inlet | 6″ ø |
| Sound | 66 dB(A) |
MF 1050
| Airflow | 900–1,100 cfm |
| Enclosure | 450 ft³ |
| Motor | 1.5 hp |
| Inlet | 8″ ø |
| Sound | 68 dB(A) |
MF 1950
| Airflow | 1,900–2,000 cfm |
| Enclosure | 2,000 ft³ |
| Motor | 3 hp |
| Inlet | 12″ ø |
| Sound | 72 dB(A) |
Revolution is in the Air
Why Choose AEROEX?
