MAM72-35V 5-Axis Production Machining Center
Lights-Out 5-Axis Production Center
The MAM72-35V is built for continuous, unattended 5-axis machining. With ±120° B-axis tilt and a full 360° C-axis, it tackles complex parts in one setup while maintaining tight tolerances and consistent surface finish. A high-speed spindle and fast tool changes keep cycle times short and throughput high—ideal for aerospace, medical, and precision job shops.
Standard controls include FANUC 31i-MB Plus or Heidenhain TNC 640, giving shops proven reliability and powerful 5-axis capability. Add pallets and automation to run lights-out and keep chips flying around the clock.
Available in multiple configurations.
Country of Origin: Japan
The MAM72-35V delivers true 5-axis simultaneous machining with a rigid platform, fast tool changes, and automation-ready design. Its high-speed spindle and HSK-A63 interface drive aggressive metal removal on aluminum through stainless and superalloys, while the rotary table’s wide tilt range completes complex geometries in one hit. With FANUC or Heidenhain control and proven long-run reliability, it’s a production workhorse for shops that measure output in parts per shift—not hours per setup.
| Specification | Details |
| Travel (X / Y / Z) | 25.6" / 28.7" / 23.6" (650 / 730 / 600 mm) |
| 5th-Axis Type | Tilting rotary table (B / C) |
| B-Axis Range | ±120° |
| C-Axis Rotation | 360° continuous |
| Table Size | Ø25.6" (Ø650 mm) |
| Max Workpiece Weight | 882 lbs (400 kg) |
| Spindle Speed | 15,000 rpm |
| Spindle Power | 35 hp (26 kW) |
| Tool Taper | HSK-A63 |
| Tool Magazine Capacity | 40 tools |
| Control | FANUC 31i-MB Plus / Heidenhain TNC 640 |
Unstoppable 5-Axis Productivity
The high-speed spindle reaches 15,000 rpm with 35 hp (26 kW) of power, delivering both rapid material removal and fine surface finishes. With B-axis tilt of ±120° and full 360° C-axis rotation, the MAM72-35V excels at complex 5-sided machining in a single setup. With a tool capacity up to 40 tools, this machine tool ensures uninterrupted cycles, while automation options support long, lights-out production runs.
15,000 rpm
35 hp (26 kW)
HSK-A63
40 tools (optional up to 530)
25.6" diameter (650 mm)
882 lbs (400 kg)
B-axis tilt ±120°, C-axis continuous 360°
Multi-pallet system, lights-out machining
5-axis simultaneous machining, automation-ready, large tool magazine
Why Choose Matsuura?
Innovation that Drives Precision
Built in Japan with precision engineering and rigorous quality control.
Industry pioneer in multi-pallet and lights-out production systems.
Decades of proven uptime in aerospace, medical, and precision machining.
Integration of advanced spindles, controls, and monitoring systems.
Strong distributor and service network ensures long-term partnership.
