JC6 3-Axis Vertical Machining Center
Compact Precision Vertical Machining Center
The YCM JC 6 is a high-performance 40-taper machining center built for precision, speed, and reliability. With FEM-analyzed structure, Meehanite® cast base, and hand-scraped slideways, it delivers exceptional rigidity and repeatability in a compact footprint. Ideal for high-precision part production across aerospace, automotive, medical, and general manufacturing industries.
Country of Origin: Taiwan
Customize Your CNC
Compact. Fast. Precise.
The JC 6 features a 12,000 rpm dual-contact CAT-40/BBT-40 spindle producing 25 hp (18.5 kW) of cutting power. Travels of 23.6 × 16.1 × 17.7 in (600 × 410 × 450 mm) and 1,890 ipm rapids make it a compact but capable performer. The Meehanite® casting, integrated spindle cooling, and 24-tool ATC system support continuous operation for demanding part runs.
Spindle by YCM
The spindle is the heart of every cut. Each YCM spindle is built and tested for power, accuracy, and long service life. The proven IDD spindle design is trusted by machinists worldwide for its reliability.
Rigid Design
FEM analysis guides YCM’s design for maximum stability under heavy cuts. Direct-drive servo motors with absolute encoders deliver fast, accurate, and repeatable motion—backed by rigid construction for unmatched precision and stiffness.
Designed for Versatility
The JC Series is designed with versatility in mind. This platform is ideal for General Parts machining across a wide spectrum of industries including Aerospace, Automotive, Medical, Energy, and more.
27.6 × 16.5 in (700 × 420 mm)
660 lb (300 kg)
FANUC 0i-MF Plus with AICC II+ and 10.4″ LCD
12,000 rpm (15,000 rpm optional)
25 hp (18.5 kW)
Dual Contact CAT-40 / BBT-40
24 Tools (Standard)
IDD spindle, Meehanite® base, FANUC control, hand-scraped precision
Why Choose YCM Alliance?
Precision you can count on.
YCM designs and casts its own bases, manufactures its own spindles, and hand-scrapes critical surfaces—ensuring unmatched quality control.
Whether you run aerospace, die/mold, or medical parts, the YCM Alliance lineup—from YCM CNC to TRIMILL to exeron to ZIERSCH to CHETO and MILLUTENSIL—delivers high-precision, high-mix solutions built for every machining need.
From auto doors and pallet changers to full robotic cells, YCM Alliance machines are designed for integration and lights-out scalability.
Built with top-tier components including Heidenhain, FANUC, HSK, and Rexroth, these machines deliver both reliability and long-term performance.
With heavy-duty cast iron construction, thermal stability systems, and proven engineering, these machines are made to hold tolerances—year after year.
