EMCO HYPERTURN 50 High-Performance CNC Turning & Milling Center
High-Performance Turning Center
The EMCO HYPERTURN 50 is a compact, multi-functional turning center built for complete machining. Its rigid two-piece base structure supports high accuracy and thermal stability, even when cutting hardened steels and aerospace-grade materials. A 12- or 16-station turret with direct drive and BMT interface supports efficient turning and milling operations.
A high-speed spindle up to 12,000 rpm and a powerful 15 kW motor deliver strong torque for precision work. The Y-axis is positioned at 90 degrees to the X-axis to improve stability and reduce overhang during milling. With automation readiness, EMCONNECT integration, and control options including Sinumerik ONE or Fanuc 31i-B Plus, the HYPERTURN 50 is well suited for automotive, aerospace, and medical production.
Country of Origin: Austria
Customize Your CNC
BEYOND STANDARD
The EMCO HYPERTURN 50 is a high-speed, multi-tasking turning center designed for efficiency and precision. With a dual-turret system, integrated Y-axis, and powerful main and counter spindles, it handles simultaneous turning, milling, and drilling with ease. Built for precision machining in steel, aluminum, and heat-resistant alloys, it’s a go-to for aerospace, medical, and general manufacturing. Automation-ready, high-speed compatible, and equipped with Siemens or Fanuc controls, the HYPERTURN 50 is ideal for high-mix, low-volume production that demands reliability and speed.
SPEED MEETS PRECISION
The EMCO HYPERTURN 50 is built for speed and precision, featuring a main spindle speed of up to 7,000 rpm with 73.8 ft-lb (100 Nm) of torque for high-efficiency turning. The driven tools reach speeds of up to 12,000 rpm, allowing for fast and precise milling and drilling operations. With a compact yet rigid design, the HYPERTURN 50 ensures stability, repeatability, and maximum productivity for complex multi-task machining.
6.9" / ±1.57" / 20.1" (175 mm / ±40 mm / 510 mm)
1,181 in/min / 590 in/min / 1,771 in/min (30 m/min / 15 m/min / 45 m/min)
9.8 ft/s² / 9.8 ft/s² / 9.8 ft/s² (3 m/s² / 3 m/s² / 3 m/s²)
0.00016" (4 µm) / 0.00008" (2 µm) / 0.00016" (4 µm)
0 - 7000 rpm / 73.8 ft-lb (100 Nm)
Why Choose EMCO?
Precision engineered. Performance delivered.
EMCO develops flexible, high-performance machining systems built for industries like aerospace, automotive, and general manufacturing.
Every EMCO machine is designed and manufactured in-house, ensuring the highest level of quality, precision, and technological innovation.
Designed for durability and efficiency, EMCO machines deliver stable performance in demanding, multi-shift environments.
From installation to maintenance and upgrades, EMCO provides full-service support to maximize uptime and productivity.
With worldwide manufacturing and service hubs, EMCO delivers reliable solutions and expert support wherever you operate.
