EMCO HT65 Powermill G1 High-Performance Turn-Mill Center
Built for Machinists. Engineered for Performance.
The EMCO HYPERTURN 65 Powermill G1 is designed for demanding multi-task machining in a single setup. With a main and counter spindle handling bar stock up to Ø3.74" (Ø95 mm) and a ±110° B-axis milling spindle, it powers through turning, milling, and drilling across tough materials including high-strength steels, titanium, and nickel-based alloys.
An HSK-T63 milling spindle, 12-station turret, and optional tool magazine with up to 80 tools keep cycle times down and production moving. Built on pre-stressed roller guides for rigidity and long-term accuracy, the HYPERTURN 65 PM G1 is automation-ready and supported by EMCONNECT digital integration for consistent, reliable output.
Country of Origin: Austria
Customize Your CNC
BEYOND STANDARD
The EMCO HYPERTURN 65 Powermill G1 is a powerhouse mill-turn center built for multi-tasking precision machining. With a ±110° B-axis milling spindle, high-torque main and counter spindles, and an optional 80-tool magazine, it’s engineered for cutting tough materials like stainless steel, Inconel, and titanium. The integrated Y-axis expands milling and drilling capabilities, while advanced automation and EMCONNECT digital control streamline complex production. Perfect for aerospace, defense, and medical industries, this machine delivers faster cycle times, seamless workflows, and pinpoint accuracy—no matter the job.
SPEED MEETS PRECISION
The B-axis milling spindle of the HYPERTURN 65 Powermill G1 delivers speeds up to 12,000 rpm with 81.1 ft-lb (110 Nm) of torque, ensuring high-speed, precise machining. The main spindle reaches 5,000 rpm, providing the power needed for both aluminum milling and heavy-duty steel turning. Direct-drive technology and rigid roller guides maintain stability, accuracy, and long-term reliability.
11.8" / ±3.9" / 47.2" (300 mm / ±100 mm / 1200 mm)
1,181 in/min / 472 in/min / 1,181 in/min (30 m/min / 12 m/min / 30 m/min)
9.8 ft/s² / 9.8 ft/s² / 9.8 ft/s² (3 m/s² / 3 m/s² / 3 m/s²)
0.00016" (4 µm) / 0.00008" (2 µm) / 0.00016" (4 µm)
±110° / 73.8 ft-lb (100 Nm)
0 - 5000 rpm / 184 ft-lb (250 Nm)
±5 arcsec / 2,950 ft-lb (4000 Nm)
B-Axis milling spindle
Why Choose EMCO?
Precision engineered. Performance delivered.
EMCO develops flexible, high-performance machining systems built for industries like aerospace, automotive, and general manufacturing.
Every EMCO machine is designed and manufactured in-house, ensuring the highest level of quality, precision, and technological innovation.
Designed for durability and efficiency, EMCO machines deliver stable performance in demanding, multi-shift environments.
From installation to maintenance and upgrades, EMCO provides full-service support to maximize uptime and productivity.
With worldwide manufacturing and service hubs, EMCO delivers reliable solutions and expert support wherever you operate.
