CX4 5-Axis High-Spec Vertical Machining Center
Compact Precision with 5-Axis Power
The YCM CX4 delivers outstanding 5-axis performance in a compact layout. Designed for simultaneous 5-axis machining of complex parts, the CX4 offers a tilting rotary table, high-speed direct-drive spindle, and rigid structure for superior precision. Ideal for aerospace, medical, and mold & die applications, this compact powerhouse helps shops increase output without sacrificing accuracy.
Country of Origin: Taiwan
Customize Your CNC
BUILT FOR PRODUCTION
The CX4 is engineered for tight spaces and tight tolerances. Its high-speed spindle and compact design make it ideal for medical, aerospace, and mold shops looking to streamline 5-axis operations. The trunnion-style rotary table ensures precision on complex geometries, while the integrated design keeps the machine thermally stable and highly repeatable.
Highly Accurate Axial Movement
- Linear guideways enable fast and smooth axial movement.
- Pre-tensioned ball screws and direct drive motors provide high torque and accurate positioning.
Rigid Structural Design
- Meehanite® components and mating surfaces are hand scraped for optimum stiffness and vibration dampening.
- Extra wide column and base ensure greater support and stability during machining.
A/C-axis Rotary Table
- A-axis: 150° (+30° / -120°)
- Table size: ø13.8" (ø350 mm)
- Max. workpiece dimension: ø15.8" x 12.2" (ø400 x 310 mm)
- Max. workload: 440 lbs (200 kg)
19.7" × 17.7" × 13.8" (500 × 450 × 350 mm)
ø19.7" (ø500 mm)
551 lbs (250 kg)
Siemens 840D
15,000 RPM
42.3 hp (31.5 kW)
HSK-A63
40 tools
±120° B-Axis, 360° C-Axis
Compact 5-axis platform for precision small part machining
Why Choose YCM Alliance?
Precision you can count on.
YCM designs and casts its own bases, manufactures its own spindles, and hand-scrapes critical surfaces—ensuring unmatched quality control.
Whether you run aerospace, die/mold, or medical parts, the YCM Alliance lineup—from YCM CNC to TRIMILL to exeron to ZIERSCH to CHETO and MILLUTENSIL—delivers high-precision, high-mix solutions built for every machining need.
From auto doors and pallet changers to full robotic cells, YCM Alliance machines are designed for integration and lights-out scalability.
Built with top-tier components including Heidenhain, FANUC, HSK, and Rexroth, these machines deliver both reliability and long-term performance.
With heavy-duty cast iron construction, thermal stability systems, and proven engineering, these machines are made to hold tolerances—year after year.
