STATION 04: TITAN-858 "Intake Flange"
| Machinist | Jessie Smith |
| Machine | SYIL X9 |
| Part Name | TITAN-858 - Intake Flange |
| Material & Provider | 6061 Aluminum - Champagne Metals |
| Industry | Automotive |
| Control | SIEMENS SINUMERIK 828D |
| Programmed In | Mastercam |
| Workholding | Custom Fixture |
| Coolant | Blaser Synergy 735 |
The TITAN-858 "Intake Flange" ties the intake tract to the engine side hardware, providing a flat, rigid sealing surface and accurate bolt pattern for leak-free airflow. Machined from 6061 aluminum for strength, corrosion resistance, and easy finishing, this part is ideal for custom manifolds, turbo plumbing, and prototype builds where repeatable alignment and surface finish matter.
Sale price$100,000.00
Featured at This Station
SYIL X9 Vertical Mill
The TITANS of CNC Promise
- Expert Guidance
- Flexible Financing*
- Service & Support
- Industry Connections
*Ask us about Section 179 write-offs
First-Class Components and Solid Construction
- Axis travels of 29.9" × 19.7" × 19.7" (760mm × 500mm × 500mm)
- 24-pocket high-speed servo tool changer (Arm Type)
- 12,000RPM CT40 spindle
- High-quality Epoxy Granite frame by SCHNEEBERGER (Swiss)
- SIEMENS SINUMERIK 828D 15" touch screen CNC Controller with 3-axis Servo Motors
Customizations
- NC rotary table servo type
- 4th axis 255mm size kits including servo motors and driver
- Taiwan Made and Gear type
- Tail Stock for 255mm NC rotary table
- Probe System: Wireless type
- Tool Setter Kits: Cable type TTC200
- Filtermist
- Through Spindle Coolant (20 Bar)
- Chip Conveyor
Ø3/4" Drill Fix Pro Drill
5689673
Ø1/4" AADE Endmill
3658818
Ø1/2" AADE Endmill
3658834
Ø8mm Ballnose Endmill
DSKA.2.080.050
Ø.670" TM25 Threadmill
Body - 3031706; Insert - 3031735
Team TITAN Favorites
HOT ITEM!
NEW ITEM!
NEW ITEM!
TITANS of CNC
Sale price$34.95
Regular price$39.95
Sale price$12,499.65
Regular price$12,999.00
Sale priceFrom $1,495.00
Regular price$3,625.00
HOT ITEM!
Academy Toolkit: TITAN Rocket LATHE Series 6466038
Mitee-Bite
Academy Toolkit: Art of Fixturing Inch (30400)
Sale priceFrom $515.00
Regular price$550.00
