SUPPORT FREE EDUCATION
SKU: 5665804
ZDET SERIES Carbide Inserts for 5720 ALUMINUM INDEXABLE MILLS
Sale price$283.60
Choose Your Insert (CR, Size, Edge):: CR 0.013" - 16M5 - Sharp
#CR016116M540Honed
PLEASE NOTE: Due to overwhelming demand for this product, the manufacturer is experiencing unexpected shipping delays beyond our control.
Keep On Cutting!
  • Solid carbide provides better rigidity than high-speed steel
  • Honed edge for roughing applications
  • Apply under unstable and/or high rotation applications (³24000 rpm spindle speed)
NOTE: Inserts will be delivered with two screws. Because of heavy force to the screw, it is important to change the screw when changing the insert.
  • Non-Ferrous Materials, Cast Iron
  • Quantity: 5 Inserts
  • Series: 5720VZ16
  • Insert Style: ZDET
  • Insert Size: 16M540
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Honed
  • Corner Radius: 0.161"
  • Insert Length: 0.906"
  • Insert Width: 0.443"
  • Insert Height: 0.197"
  • Insert Geometry: ER-721
#CR010216M525Honed
Keep On Cutting!
  • Series: 5720VZ16
  • Insert Size: 16M525
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Honed
  • Corner Radius: 0.102"
#CR008316M520Sharp
Keep On Cutting!
  • Sharp edge for finishing applications
  • Series: 5720VZ16
  • Insert Size: 16M520
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Sharp
  • Corner Radius: 0.083"
  • Insert Geometry: FR-721
#CR013116M532Sharp
Keep On Cutting!
  • Series: 5720VZ16
  • Insert Size: 16M532
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Sharp
  • Corner Radius: 0.131"
#CR024416M560Sharp
Keep On Cutting!
  • Series: 5720VZ16
  • Insert Size: 16M560
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Sharp
  • Corner Radius: 0.244"
#CR004916M512Sharp
Keep On Cutting!
  • Series: 5720VZ16
  • Insert Size: 16M512
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Sharp
  • Corner Radius: 0.049"
#CR001316M5Sharp
Keep On Cutting!
  • Series: 5720VZ16
  • Insert Size: 16M5
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Sharp
  • Corner Radius: 0.013"
  • Insert Length: 0.902"
#CR003216M508Sharp
Keep On Cutting!
  • Compatible with Shell Mill in the Academy Tool Kit
  • Series: 5720VZ16
  • Insert Size: 16M508
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Sharp
  • Corner Radius: 0.032"
#CR016116M540Sharp
Keep On Cutting!
  • Series: 5720VZ16
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Sharp
#CR006616M516Sharp
Keep On Cutting!
  • Series: 5720VZ16
  • Insert Size: 16M516
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Sharp
  • Corner Radius: 0.066"
#CR012316M530Sharp
Keep On Cutting!
  • Series: 5720VZ16
  • Insert Size: 16M530
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Sharp
  • Corner Radius: 0.123"
#CR010216M525Sharp
Keep On Cutting!
  • Series: 5720VZ16
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Sharp
#CR001516M504Sharp
Keep On Cutting!
  • Series: 5720VZ16
  • Insert Size: 16M504
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Sharp
  • Corner Radius: 0.015"
#CR012316M530Honed
Keep On Cutting!
  • Series: 5720VZ16
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Honed
#CR020516M550Sharp
Keep On Cutting!
  • Series: 5720VZ16
  • Insert Size: 16M550
  • Grade: GH1
  • Coating: Uncoated
  • Cutting Edges: 2
  • Edge Type: Sharp
  • Corner Radius: 0.205"
