STATION 30: TITAN-863 "Setup Plate"
| Machinist | Philipp Ziersch |
| Machine | Ziersch Z 510 |
| Part Name | TITAN-863 - Setup Plate |
| Material & Provider | 4140 Steel |
| Industry | Machining |
| Control | Ziersch Z-Control |
| Programmed In | Ziersch Z-Control |
| Workholding | 40" x 20" Magnetic Chuck |
| Coolant | Blaser B-Cool 650 |
The TITAN-863 Setup Plate is precision surface-ground from 4140 steel on a Ziersch Z 510 to establish flat, parallel datums for downstream machining. Balanced passes, spark-out cycles, and routine wheel dressing control heat and keep geometry stable on the 40" x 20" magnetic setup.
Sale price$100,000.00
Featured at This Station
Z 510 Surface Grinding Machine
The TITANS of CNC Guarantee
- Expert Guidance
- Flexible Financing
- Service & Support
- Industry Connections
The Z 510 offers a 39.4 × 23.6 in (1,000 × 600 mm) grinding range, a 19.7 × 39.4 in (1,000 × 500 mm) electro-permanent chuck, and 2,200 lb (1,000 kg) table load capacity. Hydraulic table drive, auto-dress cycles, and touchscreen Z-Control make it ready for production-level precision.
Tool 1
Grinding Wheel 16" x 2"
Tool 2
PART#
Tool 3
PART#
Team TITAN Favorites
HOT ITEM!
NEW ITEM!
NEW ITEM!
TITANS of CNC
Sale price$34.95
Regular price$39.95
Sale price$12,499.65
Regular price$12,999.00
Sale priceFrom $1,495.00
Regular price$3,625.00
HOT ITEM!
Academy Toolkit: TITAN Rocket LATHE Series 6466038
Mitee-Bite
Academy Toolkit: Art of Fixturing Inch (30400)
Sale priceFrom $515.00
Regular price$550.00
