STATION 27: TITAN-869 "Sodick Logo Taper"
| Machinist | Josh Scaglione |
| Machine | SODICK AL600P |
| Part Name | TITAN-869 – "Sodick" Logo Taper |
| Material & Provider | Aluminum |
| Industry | Demo |
| Control | SPW |
| Programmed In | Metalcam/Fikus |
| Workholding | Vise |
| Coolant | Deionized Water |
Featured at This Station
AL600P IGE Wire EDM
The TITANS of CNC Promise
- Expert Guidance
- Flexible Financing*
- Service & Support
- Industry Connections
Precision and Innovation in Wire-Cut EDM
Exceptional Precision: The AL600P IGE is equipped with Sodick’s patented i Groove mechanism, offering unparalleled accuracy in wire rotation. This feature ensures consistent use of new wire surfaces during machining, significantly improving the surface finish and stability when working on thick plates.
Cutting-Edge Technology: With features like advanced “Step-cut” machining for shapes with varying thickness, and a maintenance-free linear motor drive, the AL600P IGE provides high-speed, precision machining with minimal wear, thanks to its non-contact system. The built-in thermal displacement correction ensures precise operation even in challenging temperature environments.
Country of Origin: Japan
Z+ Wire
