STATION 13: TITAN-844 "Aerospace Fitting"
| Machinist | Travis Jarrett |
| Machine | EMCO HYPERTURN 50 |
| Part Name | TITAN-844 - Aerospace Fitting |
| Material & Provider | 316 Stainless Steel |
| Industry | Aerospace |
| Control | SIEMENS Sinumerik One |
| Programmed In | — |
| Workholding | Royal Collet Chucks |
| Coolant | Blaser Synergy 735 |
The TITAN-844 (Aerospace Fitting) in 316 stainless highlights tight diameters, clean edges, and a consistent surface finish—built for repeatability and inspection-ready results.
Sale price$100,000.00
Featured at This Station
EMCO HYPERTURN 50 High-Performance CNC Turning & Milling Center
The TITANS of CNC Promise
- Expert Guidance
- Flexible Financing*
- Service & Support
- Industry Connections
*Ask us about Section 179 write-offs
The EMCO HYPERTURN 50 is a high-speed, multi-tasking turning center designed for efficiency and precision. With a dual-turret system, integrated Y-axis, and powerful main and counter spindles, it handles simultaneous turning, milling, and drilling with ease. Built for precision machining in steel, aluminum, and heat-resistant alloys, it’s a go-to for aerospace, medical, and general manufacturing. Automation-ready, high-speed compatible, and equipped with Siemens or Fanuc controls, the HYPERTURN 50 is ideal for high-mix, low-volume production that demands reliability and speed.
Full Tool List
| Tool # | Holder / Body | Insert (grade / P/N) | Notes |
| 1 | DCLNR2020K12KC04 (1875199) | CNMG432UP (KCU10B / 7093230) | Standard 80° turning tool for stainless roughing. |
| 2 | KTFS200R05SCF25M Drill Body (6389289) | KTFST08125HPL (KCMS15 / 6370978) | KenTIP FS modular drill body, 5×D, through-coolant. |
| 3 | SVJBR123 (1094539) | VBGT331LF (KCU10B / 7093184) | RH 35° light finishing tool. |
| 4 | NSR2020K3 (1098795) | NJP3014R12 (KCU10B / 7237263) | Threading holder with NJP series insert for UNJ. |
| 5 | Solid Carbide Boring Bar 0.625″ | CPMT32505LF (KCU10B / 7093188) | General-purpose ID finishing. |
| 6 | HARVI II TE H2TE5RA0500R125HAR015 (7155994) | Solid End Mill (KCSM15A) | Ø0.500″, 5-flute, 0.015″ corner radius. |
| 7 | HARVI I TE H1TE4SE0063R013HA (6767731) | Solid End Mill (KCPM15) | Ø0.0625″, 4-flute. |
| 8 | B070A01600 (7070649) | Solid Drill (KCU10) | KenDrill Micro 1.6 mm, 7×D, through-coolant. |
| 9 | EVBSN26J0340 Cut-Off Blade (5941721) | EC030M03PN00CF02 (KCU25B / 7167434) | Beyond Evolution cut-off system, 26 mm blade height. |
| 10 | 3/8″ Chamfer Mill | Solid End Mill | 4-flute chamfer. |
| 11 | MDJNR124A (1808169) | DNGG431FS (KCU10B / 7090576) | RH 55° diamond tool, finishing for steel/stainless/high-temp. |
| 12 | NSR2020K3 (1098795) | NG3125RK (KCU25B / 7249789) | Grooving setup using the same NSR holder. |
| 13 | Heavy-Metal ID Boring Bar 0.750″ | CPGT3251LF (KCU10B / 7093163) | High-damping ID bar for finishing. |
Team TITAN Favorites
HOT ITEM!
NEW ITEM!
NEW ITEM!
TITANS of CNC
Sale price$34.95
Regular price$39.95
Sale price$12,499.65
Regular price$12,999.00
Sale priceFrom $1,495.00
Regular price$3,625.00
HOT ITEM!
Academy Toolkit: TITAN Rocket LATHE Series 6466038
Mitee-Bite
Academy Toolkit: Art of Fixturing Inch (30400)
Sale priceFrom $515.00
Regular price$550.00
