B8SY 3-Axis High-Spec Vertical Machining Center
3-Axis Productivity Meets Dual-Spindle Versatility
The YCM B8SY is a 3-axis vertical machining center with added dual-spindle turning capabilities. Built for high-precision parts that require both milling and turning, this hybrid platform offers integrated spindles and robust rigidity. Ideal for complex machining in a single setup, the B8SY reduces handling time and boosts part consistency.
Country of Origin: Taiwan
HYBRID POWER. PURE PRECISION.
Designed for shops looking to consolidate operations, the B8SY combines milling and turning in one machine. This hybrid setup cuts setup times and boosts efficiency for parts requiring both operations. Built with a rigid casting and YCM’s precision control platform, the B8SY brings flexibility and accuracy to every cycle.
Rigid Design
FEM analysis ensures rib and mass placement for maximum stability under heavy cutting loads. Rugged castings provide stiffness, thermal stability, and vibration control for consistent accuracy.
Spindle
YCM Turning Centers are built for flexibility, covering everything from general job shop work to high-end parts machining. Perfect for automotive, aerospace, medical, energy, and more.
Designed for Versatility
The spindle is the heart of every machine. YCM’s proven spindle design delivers long life, reliable performance, and the rigidity needed for tough cuts and repeatable precision.
Travel (X/Y/Z)
31.5" × 20.9" × 20.1" (800 × 530 × 510 mm)
Table Size
39.4" × 19.7" (1000 × 500 mm)
Max Workpiece Weight
1,102 lbs (500 kg)
Control System
Fanuc 0i-MF Plus
Spindle Speed
12,000 RPM
Why Choose YCM Alliance?
Precision you can count on.
