ZR 600 Cylindrical Grinding Center
Precision Cylindrical Grinder for Medium Parts
The Ziersch ZR 600 is a versatile cylindrical grinder built for accuracy, flexibility, and ease of use. With a 11.8 in (300 mm) max diameter, 23.6 in (600 mm) between-centers, and Z-Control automation, it handles general-purpose cylindrical grinding, shoulder grinding, and internal work with a stable, heavy-duty frame.
Country of Origin: Germany
Flexible, High-Speed Grinding
The ZR 600 supports parts up to 11.8 in (300 mm) diameter and 23.6 in (600 mm) in length, with up to 220 lb (100 kg) between centers. It features a 5.6 kW grinding head, infinitely variable spindle speed, auto infeed with dressing compensation, and Z-Control touchscreen cycles for efficient shop-floor operation.
20,000 / 30,000 / 40,000 rpm options
7.5 hp (5.6 kW)
10.4″ Z-Control touchscreen with auto infeed & dressing compensation
Max Ø11.8 in × 23.6 in (Ø300 × 600 mm) between centers
Z 23.6 in (600 mm); X/Z feed 0.00004–79 ipm (0.001–2,000 mm/min)
N/A — between-centers grinder (headstock MT5 / tailstock MT4)
220 lb (100 kg) between centers; 99 lb (45 kg) floating
66 gal (250 L) band filter with magnetic pre-separator
Value114 × 111 × 67 in (2,900 × 2,820 × 1,700 mm), approx. 9,259 lb (4,200 kg)
Preloaded linear guides (X), scraped V-ways (Z), internal grinding option, high-speed spindles
Why Choose Ziersch?
Built for grinders who demand accuracy, durability, and no-nonsense support.
Machines built by grinders for grinders—no shortcuts.
Ziersch doesn’t spread thin—they live and breathe surface grinders.
Intuitive controls mean less time training and more time cutting chips.
Solid castings and hand-finished ways hold tolerance for years.
Service and parts support you can count on wherever you're located.
