Z 510 Surface Grinding Machine
Large-Capacity Precision Surface Grinder
The Ziersch Z 510 is built for shops needing bigger grinding capacity without sacrificing accuracy. With a 39.4 × 23.6 in (1,000 × 600 mm) range, heavy cast-iron frame, and Z-Control automation, it delivers stable, repeatable results on medium-to-large workpieces.
Country of Origin: Germany
Big Envelope, Stable Cuts
The Z 510 offers a 39.4 × 23.6 in (1,000 × 600 mm) grinding range, a 19.7 × 39.4 in (1,000 × 500 mm) electro-permanent chuck, and 2,200 lb (1,000 kg) table load capacity. Hydraulic table drive, auto-dress cycles, and touchscreen Z-Control make it ready for production-level precision.
1,000–3,000 rpm
15 hp (11 kW)
10.4″ Z-Control touchscreen with auto-dress and compensation
55.1 in X / 21.7 in Y / 23.6 in table–spindle (1,400 / 550 / 600 mm)
39.4 × 19.7 in (1,000 × 500 mm) SAV electro-permanent
2,200 lb (1,000 kg) including magnet
148 gal (560 L) band filter with pre-separator
Value186 × 119 × 108 in (4,730 × 3,020 × 2,740 mm), approx. 16,050 lb (≈ 7,280 kg)
Large grinding envelope; heavy-duty chuck; Z-Control automation
Why Choose Ziersch?
Built for grinders who demand accuracy, durability, and no-nonsense support.
Machines built by grinders for grinders—no shortcuts.
Ziersch doesn’t spread thin—they live and breathe surface grinders.
Intuitive controls mean less time training and more time cutting chips.
Solid castings and hand-finished ways hold tolerance for years.
Service and parts support you can count on wherever you're located.
