Z 24 Surface Grinding Machine
Precision Surface Grinder for Toolrooms & Production
The Ziersch Z 24 is a rigid, cast-iron surface grinder sized for everyday precision work. Linear guides, hand-scraped coated slideways, and Z-Control automation deliver stable finishes and repeatable microns—shift after shift.
Country of Origin: Germany
Built Strong, Cuts True
The Z 24 offers a 15.7 × 9.8 in (400 × 250 mm) grinding range with an electro-permanent magnetic chuck, table-mounted dresser, and a band-filter coolant unit. Touchscreen Z-Control cycles with auto-dress and compensation make it ready for toolroom and small-batch production with minimal operator input.
1,000–4,500 rpm
5 hp (3.7 kW)
10.4″ Z-Control touchscreen with auto-dress and compensation
23.6 in X / 8.7 in Y / 21.3 in table–spindle (600 mm / 220 mm / 540 mm)
15.7 × 7.9 in (400 × 200 mm) SAV electro-permanent
550 lb (250 kg) including magnet
132 gal (500 L) band filter with magnetic pre-separator
Value120 × 96 × 99 in (3,050 × 2,450 × 2,510 mm), approx. 6,725 lb (≈ 3,050 kg)
Heavy cast base; Z-Control automation; electro-permanent chuck
Why Choose Ziersch?
Built for grinders who demand accuracy, durability, and no-nonsense support.
Machines built by grinders for grinders—no shortcuts.
Ziersch doesn’t spread thin—they live and breathe surface grinders.
Intuitive controls mean less time training and more time cutting chips.
Solid castings and hand-finished ways hold tolerance for years.
Service and parts support you can count on wherever you're located.
