SC6525 Carbide Inserts General Duty in Steel CR 0.031" / 0.800mm (10-PACK) 6010774
High-Feed Milling Inserts
- Improved cost per edge.
- Primary: Steel
- Secondary: Stainless Steel, Cast Iron
- Quantity:10
- Cutting Edges per Insert: 4
- Grade:SC6525
- Coating:Al2 O3
- Tool Family:XDPT-12-D41
- [D] Insert Size (Inch):0.500"
- [D] Insert Size (Metric):12.700mm
- [L10] Edge Length (Inch):0.500"
- [L10] Edge Length (Metric):12.700mm
- [S] Insert Thickness (Metric):5.556mm
- Corner Radius (Inch):0.031"
- Corner Radius (Metric):0.800mm
