X500 Carbide Inserts Heavy Duty in High-Temp Alloys CR 0.031" / 0.800mm (5-PACK) 6010729
High-Feed Milling Inserts
- Improved cost per edge.
- Primary: High-Temp Alloys, Steel, Stainless Steel
- Secondary:
- Quantity:5
- Cutting Edges per Insert: 4
- Grade:X500
- Coating:TiN
- Tool Family:XDPT-09-D41
- [D] Insert Size (Inch):0.375"
- [D] Insert Size (Metric):9.525mm
- [L10] Edge Length (Inch):0.375"
- [L10] Edge Length (Metric):9.525mm
- [S] Insert Thickness (Inch):0.1874"
- [S] Insert Thickness (Metric):4.760mm
- Corner Radius (Inch):0.031"
- Corner Radius (Metric):0.800mm
