Flat rate shipping applied at checkout. If actual rate varies, the final order amount will be adjusted.
Efficient CNC Tank Cleaning with the RAM OIL 200 MP Industrial Vacuum
High-Capacity CNC Tank Cleaning
The RAM OIL 200 MP is a high-capacity industrial vacuum designed for cleaning CNC machine tanks and recovering cutting oil and coolant mixed with swarf. Built for production shops, it separates solids from liquids during suction, allowing recovered fluids to be reused while solids are collected safely.
Key Features:
- Integrated Solid-Liquid Separation: Filters swarf from oil and coolant during vacuuming.
- Large Recovery Capacity: Designed for cleaning large CNC tanks with fewer interruptions.
- Automatic Liquid Discharge: Built-in pump allows controlled draining of recovered fluids.
- Swarf Collection Basket: Captures solid material for easy removal and disposal.
- Mobile Design: Mounted on industrial casters for easy movement around the shop.
The RAM OIL 200 MP helps reduce machine downtime during maintenance and supports cleaner, more consistent fluid management in CNC environments.
Includes:
- Oil and swarf recovery system
- Integrated filtration cartridge
Metal Cleaning Accessory Kit
Maximize the performance of your industrial vacuum cleaner with our Metal Cleaning Accessory Kit, engineered for seamless CNC machine maintenance. This all-in-one kit simplifies the handling of metal shavings and swarf for an effortless cleaning experience.
Key Components:
- Heavy-Duty Hoses: High-quality, flexible hoses built to resist oil and metal debris, ensuring long-term durability.
- Precision Nozzles: A variety of nozzles tailored for targeted suction across different surfaces and debris types.
- Tough Brushes: Sturdy brushes designed to scrub and loosen swarf and metal shavings from machine surfaces.
- Quick-Connect Couplings: Fast, easy-to-use couplings that streamline the attachment process.
Benefits:
- Increased Efficiency: Simplifies CNC machine maintenance, minimizing downtime.
- Boosted Performance: Optimizes vacuum operation by equipping it with the right tools for every task.
- User-Friendly: Designed for quick setup and hassle-free storage.
- Versatile: Ideal for tackling a range of cleaning jobs, from oil and coolant spills to removing metal debris.
High-Capacity Oil and Chip Recovery for CNC Machines
The Depureco RAM OIL 200 MP is built for CNC shops that manage large volumes of coolant, oil, and metal chips every day. With a high-capacity steel tank, integrated discharge pump, and continuous-duty performance, it supports fast machine cleanout without interrupting production. Designed for demanding shop floors, the RAM OIL 200 MP handles oil recovery and swarf separation in a single, efficient process.
RAM OIL 200 MP
Separate oil and metal chips efficiently from CNC machines, tanks, and shop floors.
