NEW QuantuMike IP65 Digimatic Micrometer
#all
- Faster measurement with 2mm per revolution instead of the standard 0.5mm.
- A patented ratchet thimble mechanism helps ensure repeatability.
- A function lock helps prevent errors.
- IP65 protection level for excellent resistance against water and dust.
- Certificate of inspection is provided.
- Supplied in a fitted plastic case.
#01in
- Measuring range: 0-1" (0-25.4mm)
- Resolution: 0.00005" (0.001mm)
- Accuracy: ±0.00005" (±1µm)
- Flatness: 0.000012" (0.3µm)
- Parallelism: 0.00004" (1µm)
- Measuring faces: Carbide tipped
- Display: LCD
- Battery: SR44 (1 pc.), 938882
- Battery life: Approx. 2.4 years under normal use
- Dust/Water protection level: IP65
#12in
- Measuring range: 1-2" (25.4-50.8mm)
- Display: LCD
#23in
- Measuring range: 2-3" (50.8-76.2mm)
- Parallelism: 0.00008" (2µm)
- Display: LCD
#34in
- Measuring range: 3-4" (76.2-101.6mm)
- Display: LCD
Sale price$346.45
Regular price$358.00 (/)
