MP9 5-Axis Ultra High-Precision Machining Center
Ultra-Precision 5-Axis Machining Center
The EXERON MP9 is designed for demanding industries where microns matter. With high rigidity, thermal stability, and direct-drive rotary axes, it delivers flawless 5-axis simultaneous machining. Aerospace, die/mold, and medical benefit from its powerful 36,000 RPM spindle and advanced thermal compensation, enabling mirror-like surface finishes on complex parts.
The robust table handles workpieces up to 551 lbs (250 kg), with axis travels of 28.5" × 24.6" × 15.7" (725mm × 625mm × 400mm). From complex titanium parts to graphite electrodes, the MP9 keeps tight tolerances and high throughput. Ideal for any shop where quality isn’t optional—it’s essential.
Country of Origin: Germany
BUILT FOR PRODUCTION
The MP9 is a 5-axis machining center built for ultra-precise applications. With axis accuracy down to <1µm and a 36,000 RPM HSK-E50 spindle, it’s ideal for aerospace, die/mold, and precision medical parts. Its direct-drive rotary axes offer smooth, backlash-free motion for flawless contouring. This machine gives serious shops the edge they need when tolerances are non-negotiable.
Travel (X/Y/Z)
28.5” × 24.6” × 15.7” (725mm × 625mm × 400mm)
Table Size
ø6.22” (ø412mm)
Max Workpiece Weight
551 lbs (250 kg)
Control System
Heidenhain TNC640
Spindle Speed
36,000 RPM
Why Choose EXERON, a YCM Alliance Brand?
Built for shops that refuse to compromise on precision, speed, or support.
