Digimatic High Indicator (0-2" Range)
- SPC output capabilities - allows for easier, faster data management in real time
- Go/No-Go judgements are performed by setting the upper and lower tolerances; screen turns from green to red when a tolerance is exceeded
- ABSOLUTE (ABS) linear scale eliminates the need for setting the origin point every time the micrometer is powered on
- Origin reset is not required even when data is re-displayed after disappearance due to insufficient illumination during use
- Functions include: Origin set/preset, zero-set, Go/No-Go judgement, maximum/minimum value hold, analog bar, runout measurement, resolution switching, counting direction switching, power On/Off, data output and inch/mm conversion
- Alarm: Low voltage, counting value composition error, over-flow error and tolerance limit setting error
- Unlimited response speed eliminates over-speed errors
- An integrated analog bar indicator handles upper and lower limit approaching and zero approaching
- Sealed housing meets IP30 rating for dust and water protection
| Specification | Details |
| Measuring Range | 0 to 2"/0 to 50.8 mm |
| Resolution | 0.0001, 0.0005, 0.00005, 0.001"/0.001, 0.01 mm |
| Accuracy | ±0.00012" |
| Measuring Force | 2.3 N or less |
| Maximum Response Speed | Unlimited |
| Selectable Resolution | Yes |
| SPC Output | Yes |
| Display | LCD |
| Length Standard | ABSOLUTE electrostatic capacitance type linear encoder |
| Power Supply | 9 V DC |
| Back Type | Flat back |
| Stem Diameter | ⅜" |
| Thread Type | 4-48 UN |
- General manufacturing
- Aerospace
- Automotive
- Defense
- Electronics
- Energy
- Plastics and rubber
Sale price$967.74
Regular price$1,000.00
