Modular XYZ Xpansion™ Clamps (Press Fit Pins) - BACKORDERED
TITAN's go-to clamps for advanced fixturing and workholding setups!
- For Tombstone, Grid Plate and Fixture Plate applications
- Intended for press fit or close tolerance removable slide fit applications
- Install in a precision bore or a bushing with the center threaded for the Tapered screw
- If precise location is not necessary, pin can be used on top of fixture plate
#14174PH
- Feature: Press Fit Pin
- [G] Min. Machineable Dia.: .219"
- Screw Size: 5-40
- Max Torque: 1.6 ft-lbs
- Holding Force: 420 lbs
#38174PH
- [G] Min. Machineable Dia.: 0.281"
- Screw Size: 8-32
- Max Torque: 3.6 ft-lbs
- Holding Force: 950 lbs
#12174PH
- [G] Min. Machineable Dia.: 0.413"
- Screw Size: 1/4-20
- Max Torque: 13.3 ft-lbs
- Holding Force: 1900 lbs
#58174PH
- [G] Min. Machineable Dia.: 0.472"
- Screw Size: 5/16-18
- Max Torque: 27.6 ft-lbs
- Holding Force: 2500 lbs
#6mm174PH
- [G] Min. Machineable Dia.: 5.500mm
- Screw Size: M3
- Max Torque: 2.8 N.m
- Holding Force: 1868 N
#10mm174PH
- [G] Min. Machineable Dia.: 7.500mm
- Screw Size: M4
- Max Torque: 5 N.m
- Holding Force: 4228 N
#12mm174PH
- [G] Min. Machineable Dia.: 10.500mm
- Screw Size: M6
- Max Torque: 17 N.m
- Holding Force: 8455 N
#16mm174PH
- [G] Min. Machineable Dia.: 12.000mm
- Screw Size: M8
- Max Torque: 34 N.m
- Holding Force: 11125 N
#1412L14
- Screw Size: 5-40
#3812L14
- Screw Size: 8-32
#1212L14
#5812L14
#6mm12L14
- Screw Size: M3
#10mm12L14
- Screw Size: M4
- Max Torque: 5 N.m
#12mm12L14
- Screw Size: M6
#16mm12L14
- Screw Size: M8
