TalonGrip™ Fixture Grip
TITAN's go-to grips for advanced fixturing and workholding setups!- Ideal for small lot sizes, difficult applications or proto-type work when building a fixture would not be beneficial
- An effective solution when downforce or additional holding force is necessary
- Jaws are not heat-treated to allow for custom modifications
#34FixtureGrip060120
Technical Data- Quantity: 2
- Rec. Grip Height: .060" - .120"
- Screw Size: 10-32
- Max Torque: 4.5 ft-lbs
- Holding Force: N/A
#1FixtureGrip060120
- Screw Size: 10-32
#1X1FixtureGrip060120
Technical Data- Quantity: 1
- Screw Size: 5/16-18
- Max Torque: 25 ft-lbs
#34FixtureGrip1500mm3000mm
- Rec. Grip Height: 1.500mm - 3.000mm
- Screw Size: M5
- Max Torque: 8 N.m.
#1FixtureGrip1500mm3000mm
- Screw Size: M5
#1X1FixtureGrip1500mm3000mm
- Screw Size: M8
- Max Torque: 35 N.m.
Sale price$33.50
