Modular Pitbull® Clamps (Compact or Slotted, Multiple Sizes)
TITAN's go-to clamps for advanced fixturing and workholding setups!#KnifeEdgeMediumCompact516
- Ideal for clamping work pieces in series by using the back surface of a clamp to locate the next work piece
- The back of the clamp is ground square to the bottom for precise location of parts
- The height of the clamp can be adjusted by the depth of the milled slot used to locate the clamp
- Tungsten Carbide coating can be added to increase holding force
- Feature: Knife Edge
- [H] Clamp Travel: 0.024"
- Mounting Screws: 5/16"
- Screw Size: 5/16"
- Max Torque: 14.5 ft-lb
- Holding Force: 3600 lbs
#KnifeEdgeLargeCompact38
- [H] Clamp Travel: 0.050"
- Mounting Screws: 3/8"
- Screw Size: 3/8"
- Max Torque: 30 ft-lb
- Holding Force: 6000 lbs
#KnifeEdgeMediumSlotted12
- Increased versatility through its unique riser design
- Supports the work piece off the machine table for through milling and drilling
- Designed for use on work cubes and machine tables with tapped holes or T-slot configurations
- Slot: Closed
- Mounting Screws: 1/2"
- Screw Size: 1/2"
#KnifeEdgeLargeSlotted58
- Slot: Closed
- Mounting Screws: 5/8"
- Screw Size: 5/8"
#KnifeEdgeMediumCompactM8
- Screw Size: M8
- Max Torque: 22.5 N.m
- Holding Force: 16000 N
#KnifeEdgeLargeCompactM10
- Screw Size: M10
- Max Torque: 40.6 N.m
- Holding Force: 26000 N
#KnifeEdgeMediumSlottedM12
- Slot: Closed
- Screw Size: M12
#KnifeEdgeLargeSlottedM16
- Slot: Closed
- Screw Size: M16
#BluntEdgeMediumCompact516
- Feature: Blunt Edge
- [H] Clamp Travel: 0.610mm
- Mounting Screws: M8
- Screw Size: 5/16"
#BluntEdgeLargeCompact38
- [H] Clamp Travel: 1.270mm
- Mounting Screws: M10
- Screw Size: 3/8"
#BluntEdgeMediumSlotted12
- Slot: Closed
- Mounting Screws: M12
- Screw Size: 1/2"
#BluntEdgeLargeSlotted58
- Slot: Closed
- Mounting Screws: M16
- Screw Size: 5/8"
#BluntEdgeMediumCompactM8
- Screw Size: M8
#BluntEdgeLargeCompactM10
- Screw Size: M10
#BluntEdgeMediumSlottedM12
- Slot: Closed
- Screw Size: M12
#BluntEdgeLargeSlottedM16
- Slot: Closed
- Screw Size: M16
