ID Xpansion™ Clamps (Multiple Sizes)
TITAN's go-to clamps for advanced fixturing and workholding setups!- Low profile
- Ideal for secondary operations on lathe parts
- Easily machined to size on lathe or mill
- Excellent for palletized setups
- Allows more parts per workcube or fixture plates
- Heat-treated and coated screw for long life
- Clamp body made of mild steel for machinability
- Tighten with hex key or hydraulic pull cylinders
- Longer screws available for hydraulic applications
#Size00Inch
Technical Data- Quantity: 1
- Clamp Size: #00
- [F] Clamp Diameter: .290"
- [G] Min. Machineable Dia.: .160"
- Screw Size: 2-56
- Max Torque: .5 ft-lbs
- Holding Force: 250 lbs
#Size0Inch
- Clamp Size: #0
- [F] Clamp Diameter: 0.490"
- [G] Min. Machineable Dia.: 0.280"
- Screw Size: 8-32
- Max Torque: 3.6 ft-lbs
- Holding Force: 950 lbs
#Size1Inch
- Clamp Size: #1
- [F] Clamp Diameter: 0.560"
- [G] Min. Machineable Dia.: 0.480"
- Screw Size: 1/4-20
- Max Torque: 13.3 ft-lbs
- Holding Force: 1900 lbs
#Size2Inch
- Clamp Size: #2
- [F] Clamp Diameter: 0.790"
- [G] Min. Machineable Dia.: 0.530"
- Screw Size: 5/16-18
- Max Torque: 27.6 ft-lbs
- Holding Force: 2500 lbs
#Size3Inch
- Clamp Size: #3
- [F] Clamp Diameter: 1.060"
- [G] Min. Machineable Dia.: 0.710"
- Screw Size: 3/8-16
- Max Torque: 49.3 ft-lbs
- Holding Force: 4500 lbs
#Size4Inch
- Clamp Size: #4
- [F] Clamp Diameter: 1.390"
- [G] Min. Machineable Dia.: 0.900"
- Screw Size: 1/2-13
- Max Torque: 120 ft-lbs
- Holding Force: 5900 lbs
#Size5Inch
- Clamp Size: #5
- [F] Clamp Diameter: 1.650"
- [G] Min. Machineable Dia.: 1.150"
- Screw Size: 5/8-11
- Max Torque: 224 ft-lbs
- Holding Force: 10000 lbs
#Size6Inch
- Clamp Size: #6
- [F] Clamp Diameter: 2.030"
#Size7Inch
- Clamp Size: #7
- [F] Clamp Diameter: 3.060"
#Size8Inch
- Clamp Size: #8
- [F] Clamp Diameter: 4.060"
#Size9Inch
- Clamp Size: #9
- [F] Clamp Diameter: 6.890"
#Size10Inch
- Clamp Size: #10
- [F] Clamp Diameter: 9.850"
- Max Torque: 125 ft-lbs
- Holding Force: 6000 lbs
#Size00Metric
- Clamp Size: #00
- [F] Clamp Diameter: 7.400mm
- [G] Min. Machineable Dia.: 4.100mm
- Screw Size: M2
- Max Torque: .70 N.m
- Holding Force: 1113 N
#Size0Metric
- Clamp Size: #0
- [F] Clamp Diameter: 12.400mm
- [G] Min. Machineable Dia.: 7.100mm
- Screw Size: M4
- Max Torque: 5 N.m
- Holding Force: 4228 N
#Size1Metric
- Clamp Size: #1
- [F] Clamp Diameter: 14.200mm
- [G] Min. Machineable Dia.: 12.200mm
- Screw Size: M6
- Max Torque: 17 N.m
- Holding Force: 8455 N
#Size2Metric
- Clamp Size: #2
- [F] Clamp Diameter: 20.000mm
- [G] Min. Machineable Dia.: 13.500mm
- Screw Size: M8
- Max Torque: 34 N.m
- Holding Force: 11125 N
#Size3Metric
- Clamp Size: #3
- [F] Clamp Diameter: 27.000mm
- [G] Min. Machineable Dia.: 18.000mm
- Screw Size: M10
- Max Torque: 60 N.m
- Holding Force: 20025 N
#Size4Metric
- Clamp Size: #4
- [F] Clamp Diameter: 35.300mm
- [G] Min. Machineable Dia.: 23.000mm
- Screw Size: M12
- Max Torque: 150 N.m
- Holding Force: 26255 N
#Size5Metric
- Clamp Size: #5
- [F] Clamp Diameter: 42.000mm
- [G] Min. Machineable Dia.: 29.300mm
- Screw Size: M16
- Max Torque: 280 N.m
- Holding Force: 44500 N
#Size6Metric
- Clamp Size: #6
- [F] Clamp Diameter: 51.500mm
- Screw Size: M16
#Size7Metric
- Clamp Size: #7
- [F] Clamp Diameter: 77.700mm
- Screw Size: M16
#Size8Metric
- Clamp Size: #8
- [F] Clamp Diameter: 103.000mm
- Screw Size: M16
#Size9Metric
- Clamp Size: #9
- [F] Clamp Diameter: 175.000mm
- Screw Size: M16
#Size10Metric
- Clamp Size: #10
- [F] Clamp Diameter: 250.200mm
- Screw Size: M16
- Max Torque: 170 N.m
- Holding Force: 26000 N
