TalonGrip™ 3/4" Vise Jaw Grip (2-Pack) ACADEMY TOOL KIT
THE ART OF FIXTURING Tool Kit includes all of the tooling you need to complete the Art of Fixturing learning series projects, including the innovativeTalonGrip. This simple bolt on system that will allow you to perform aggressive machining operations while clamping on as little as .060 (1.5mm) of an inch. TalonGrips are also available individually for fixturing with Pitbull and Dyna-Force Clamps or for soft jaw applications.
Stock Up on Your Favorite Workholding!- Ideal for small lot sizes, difficult applications or proto-type work when building a fixture would not be beneficial
- An effective solution when downforce or additional holding force is necessary
- Jaws are not heat-treated to allow for custom modifications
- Quantity: 2
- Screw Size: 10-32"
- Max Torque: 4.5 ft-lb
- Holding Force: N/A
