Flat rate shipping applied at checkout. If actual rate varies, the final order amount will be adjusted.
Compact CNC Sump Cleaning
The M130 OIL P is a compact industrial vacuum designed for routine CNC sump and tank cleaning. It is built to recover lubricating oil and cutting fluids mixed with swarf while separating solids from liquids during suction.
Key Features:
- Solid-Liquid Separation: Filters swarf and sludge from recovered fluids.
- Compact Footprint: Fits well in shops with limited floor space.
- Fluid Recovery: Allows oil and coolant to be reused or disposed of cleanly.
- Simple Operation: Designed for regular maintenance tasks without added complexity.
- Mobile Design: Easy to move between machines.
The M130 OIL P is well suited for shops that perform frequent machine cleaning and want a straightforward solution for managing fluids and debris.
Includes:
- Integrated oil and swarf filtration system
Cleaning Kit Info
Vacuum Accessory Kit for Oil and Swarf
Our Vacuum Accessory Kit for oil and swarf is designed to complement your industrial vacuum cleaner, enhancing its performance in CNC machine maintenance. This comprehensive kit ensures efficient handling of oil, lubricants, coolants, metal shavings, and swarf, providing a seamless cleaning experience.
Key Components:
- Durable Hoses: High-quality, flexible hoses designed to withstand oil and metal debris, ensuring longevity and reliability.
- Precision Nozzles: Various nozzles for targeted suction, optimized for different surfaces and debris types. Quick-Connect Couplings: Easy-to-use couplings for fast attachment and detachment, streamlining the cleaning process.
- Accessory Basket: Convenient basket to organize and store all accessories, keeping them within easy reach.
- Hose Holder Hooks: Two robust hooks to neatly store hoses when not in use, maintaining a tidy workspace.
Benefits:
- Enhanced Efficiency: Streamlines the cleaning and maintenance of CNC machines, reducing downtime.
- Improved Performance: Ensures optimal operation of your vacuum cleaner by providing the right tools for the job.
- User-Friendly Design: Easy-to-use components designed for quick setup and convenient storage.
- Versatility: Suitable for a wide range of cleaning tasks, from oil and coolant spills to metal debris removal.
Serious Cleanup for Serious Shops
Keep CNC work areas clean and productive with the Depureco M130 Industrial Vacuum. Designed for continuous sump and machine maintenance, the M130 handles lubricating oil, coolant, swarf, and metal chips with ease. Built for demanding shop environments, it delivers reliable performance for heavy-duty cleaning without slowing production.
M130 OIL P
Easily separate oil and metal chips from tanks, tables and machine tools.
