Flat rate shipping applied at checkout. If actual rate varies, the final order amount will be adjusted.
Flagship Performer
The M100 is Depureco's flagship single-phase industrial vacuum, known for its exceptional power and performance. With 3 By-Pass motors, it achieves a power output of 3.3 HP, making it ideal for handling dust, shavings, liquids, and more.
Key Features:
- Powerful Suction: 3 By-Pass motors delivering 3.3 HP.
- Excellent Filtration: Polyester pocket filter with 1µ filtration efficiency, M Class certified by BIA. Customizable filters available for specific needs:
- Anti-static filters to prevent electrostatic charges
- NOMEX filters for high temperatures up to 482°F
- Teflon-coated filters for wet materials
- PTFE nanotechnology filters for challenging dust particles
- Manual Filter Cleaning: Easy and effective filter cleaning with a lever-operated manual system.
- Convenient Disposal: Detachable container on wheels for easy collection and disposal of vacuumed material. Available in 100-liter capacity, with support for four castor wheels for safe handling even when full. A tiltable kit for containers is available upon request.
- Versatile Options: M100 Longopac version for those who prefer a direct bagging system.
The M100 industrial vacuum cleaner combines power, versatility, and convenience, making it an ideal choice for various challenging applications.
Includes:
- Metal Chips Cleaning Kit
Cleaning Kit Info
Metal Cleaning Accessory Kit
Maximize the performance of your industrial vacuum cleaner with our Metal Cleaning Accessory Kit, engineered for seamless CNC machine maintenance. This all-in-one kit simplifies the handling of metal shavings and swarf for an effortless cleaning experience.
Key Components:
- Heavy-Duty Hoses: High-quality, flexible hoses built to resist oil and metal debris, ensuring long-term durability.
- Precision Nozzles: A variety of nozzles tailored for targeted suction across different surfaces and debris types.
- Tough Brushes: Sturdy brushes designed to scrub and loosen swarf and metal shavings from machine surfaces.
- Quick-Connect Couplings: Fast, easy-to-use couplings that streamline the attachment process.
Benefits:
- Increased Efficiency: Simplifies CNC machine maintenance, minimizing downtime.
- Boosted Performance: Optimizes vacuum operation by equipping it with the right tools for every task.
- User-Friendly: Designed for quick setup and hassle-free storage.
- Versatile: Ideal for tackling a range of cleaning jobs, from oil and coolant spills to removing metal debris.
Keep your chips off the table.
Efficiently clean your workspace with the Depureco M100 Industrial Vacuum. The only 120V industrial vacuum that easily collects metal chips, fine dust, and liquids in your CNC shop.
Unstoppable in any heavy-duty application.
Depureco M100 OIL
A must-have compressed air industrial vacuum for oil and chips.
