Replacement Filters for WM 2500
- Mist Collector Size: WM-2500
- Coolant Type: Oil / Emulsion
Country of Origin: Latvia
Download the Instruction Manual
Download the Filter Maintenance Guide
Save Money and Clear the Air
The Filter Kits bundle both the pre and main filter into one cost-saving package. Stock up on the filters you need to keep your air clean and budget balanced.
Oil-Emulsion Filters
The Pre-Filter captures large particles and combines mist droplets from emulsions. The Main Filter uses specialized media to target finer particulates and effectively maintain clean air in your shop.
For use only in oil and water-based coolant applications.
HEPA 13
HEPA filters capture at least 99.97% of all particles as small as 0.3 microns, including fine dust and smoke particles, exceeding typical health and safety regulations in precision manufacturing environments.
