LH-600 Linear Height Gage
Product Benefits
- Intuitive operation and outstanding ease of use
- Best-in-class accuracy of ± (1.1+0.6L/600) μm
- Easy to operate using keypad and touch screen navigation
- Conduct various measurements: 2D measurement and perpendicularity measurement with just one tool (optional probes available)
- Enhanced data output functions make it easier to manage measurement data
- Measuring Range (Metric): 0 to 977 mm (600 mm)
- Measuring Range (Inch): 0 to 38 in (24 in)
- Resolution (Metric): 0.0001/ 0.001/ 0.01/ 0.1 mm (selectable)
- Resolution (Inch): 0.000001/ 0.00001/ 0.0001/ 0.001 in (selectable)
- Indication Accuracy: ± (1.1 + 0.6L / 600) μm [L = Measured length (mm)]
- Repeatability:
- Plane: 0.4 μm (2 σ)
- Hole: 0.9 μm (2 σ)
- Perpendicularity (Forward and Backward): 5 µm (After Compensation)
- Straightness (Forward and Backward): 4 µm (Mechanical Accuracy)
- Driving Method (Speed): Motor-Driven (5, 10, 15, 20, 25, 30, 40 mm/s: 7 steps) / Manual
- Scale Unit: Photoelectric Incremental Encoder STVC-20Z
- Measuring Force: 1 N (Automatic Constant-Force Function)
- Main Unit Moving Mode: Full-Floating (Moving) / Semi-Floating (Measuring) Air Bearing (Built-in Compressor)
- Display Unit: 8.4 in Touch-Screen, LCD
- Adjustment of Display Unit:
- Stepless tilt adjustment: 0 to 40°
- Stepless swivel adjustment: -30 to 180°
- Preventive Maintenance: Scale Status Notification; Calibration Schedule Notification
- Probe Diameter Compensation:
- Semi-automatic compensation using the probe diameter calibration block (standard accessory)
- Compensation by inputting the probe diameter
- Power Supply: AC Adapter 100-240V±10%; 50/60Hz/ Battery (NiMH)
- Battery Operation Time: Battery Powered (Standard): 4 Hours; Powered by 2 Batteries: 8 Hours
- Battery Charging Time: Approx. 3.5 Hours (Can be Used While Charging)
- Dimensions (W×D×H): 238 (W) × 492 (D) × 996 (H) mm
- Mass: 26.1 kg / 26.6 kg
- Operating Temperature / Humidity Ranges: 5 to 40° C / 20 to 80% RH (non-condensing)
- Data Output: Digimatic d2/S1 (Bi-Directional Communication)
Standard Accessories
- Stepped Probe, Ball-Diameter Compensation Block (with Cover and Base), Auxiliary Weight (2 pcs. Pre-mounted), Battery Pack (1 pc), AC Adapter, Clear Cover, Conveying Handle, Cap, Hex Wrench, Manual Set, Inspection Certificate, Touch Pen, Protective Sheet, Phillips Screwdriver
Country of Origin: Japan
Sale price$11,032.25
Regular price$11,400.00
