JC10 3-Axis Vertical Machining Center
Compact Performance Vertical Machining Center
The YCM JC10 combines precision, rigidity, and space-saving design for small-part and high-accuracy applications. Its Meehanite® cast frame and high-speed 12,000 rpm spindle deliver reliable machining for mold, medical, and general engineering shops. Designed for rigidity and precision, it ensures stable cutting across a range of materials, while maintaining a small footprint for easy integration into any workshop.
Advanced control options, thermal stability, and robust construction make the JC10 a smart investment for shops that need speed, accuracy, and productivity in one compact machine.
Country of Origin: Taiwan
Customize Your CNC
SMART SIZE. SERIOUS POWER.
The YCM JC10 is designed for small-part production and precision applications where space is at a premium. With a 12,000 rpm spindle, rigid Meehanite® casting, and advanced controls, it delivers high accuracy and reliable cutting performance. Its compact footprint and efficient design make it ideal for mold, medical, and prototyping shops. Simple to integrate and easy to maintain, the JC10 offers serious performance for any small-format machining need.
Spindle by YCM
The spindle is the heart of every cut. Each YCM spindle is built and tested for power, accuracy, and long service life. The proven IDD spindle design is trusted by machinists worldwide for its reliability.
Rigid Design
FEM analysis guides YCM’s design for maximum stability under heavy cuts. Direct-drive servo motors with absolute encoders deliver fast, accurate, and repeatable motion—backed by rigid construction for unmatched precision and stiffness.
Designed for Versatility
The JC Series is designed with versatility in mind. This platform is ideal for General Parts machining across a wide spectrum of industries including Aerospace, Automotive, Medical, Energy, and more.
40.1” (1,020 mm) / 20.4” (520 mm) / 21.2” (540 mm)
44.1” x 20.4” (1,120 x 520 mm)
1,102 lb (500 kg)
FANUC 0i-MF Plus
12,000 rpm (15,000 rpm optional)
25 hp (18.5 kW)
Dual Contact CAT-40 / BBT-40
30 Tools (40 Tools optional)
Compact design, Meehanite® casting, high-speed spindle
Why Choose YCM Alliance?
Precision you can count on.
YCM designs and casts its own bases, manufactures its own spindles, and hand-scrapes critical surfaces—ensuring unmatched quality control.
Whether you run aerospace, die/mold, or medical parts, the YCM Alliance lineup—from YCM CNC to TRIMILL to exeron to ZIERSCH to CHETO and MILLUTENSIL—delivers high-precision, high-mix solutions built for every machining need.
From auto doors and pallet changers to full robotic cells, YCM Alliance machines are designed for integration and lights-out scalability.
Built with top-tier components including Heidenhain, FANUC, HSK, and Rexroth, these machines deliver both reliability and long-term performance.
With heavy-duty cast iron construction, thermal stability systems, and proven engineering, these machines are made to hold tolerances—year after year.
