HYDRAULIC CHUCK REDUCER SLEEVES 12M - 32M (METRIC with METRIC BORES)
#12mmOD3mmID40mm
Kennametal® Hydraulic Reduction Sleeves are designed for high-precision clamping of straight cylindrical cutting tool shanks. The self-sealing design enables efficient use of through-coolant cutting tools when the cutting tool shank completely engages the full gripping length of the sleeve.
Designed for Precision, Stability, and Efficiency- Accelerated feed rates offer increased productivity
- Four-wall pocket provides insert stability
- One-piece design with slot configuration to seal coolant
- Through coolant standard for improved tool life, hole finish, and chip removal
- Cutting tool must be cylindrical and have a through hole when using coolant
- Units Supported: Metric with Metric Bores
- Adapter Style: Straight Shank
- Sleeve Series: HC12M
- Shank Outer Diameter (Metric): 12.000mm"
- Shank Inner Diameter (Metric): 3.000mm
- Shank Length (Metric): 40.000mm
- Gage Length (Metric): 4.000mm
- Overall Length (Metric): 44.000mm
#12mmOD4mmID40mm
- Shank Inner Diameter (Metric): 4.000mm
#12mmOD5mmID40mm
- Shank Inner Diameter (Metric): 5.000mm
#12mmOD6mmID40mm
- Shank Inner Diameter (Metric): 6.000mm
#12mmOD7mmID40mm
- Shank Inner Diameter (Metric): 7.000mm
#12mmOD8mmID40mm
- Shank Inner Diameter (Metric): 8.000mm
#12mmOD9mmID40mm
- Shank Inner Diameter (Metric): 9.000mm
#12mmOD10mmID40mm
- Shank Inner Diameter (Metric): 10.000mm
#20mmOD3mmID50mm
- Sleeve Series: HC20M
- Shank Outer Diameter (Metric): 20.000mm"
- Overall Length (Metric): 54.000mm
#20mmOD4mmID50mm
#20mmOD5mmID50mm
#20mmOD6mmID50mm
#20mmOD7mmID50mm
#20mmOD8mmID50mm
#20mmOD9mmID50mm
#20mmOD10mmID50mm
#20mmOD11mmID50mm
- Shank Inner Diameter (Metric): 11.000mm
#20mmOD12mmID50mm
- Shank Inner Diameter (Metric): 12.000mm
#20mmOD13mmID50mm
- Shank Inner Diameter (Metric): 13.000mm
#20mmOD14mmID50mm
- Shank Inner Diameter (Metric): 14.000mm
#20mmOD15mmID50mm
- Shank Inner Diameter (Metric): 15.000mm
#20mmOD16mmID50mm
- Shank Inner Diameter (Metric): 16.000mm
#25mmOD3mmID56mm
- Sleeve Series: HC25M
- Shank Outer Diameter (Metric): 25.000mm"
- Shank Length (Metric): 56.000mm
- Overall Length (Metric): 60.000mm
#25mmOD4mmID56mm
#25mmOD5mmID56mm
