HYDRAULIC CHUCK REDUCER SLEEVES 20M - 32M (METRIC with INCH BORES)
#20mmOD316ID50mm
Kennametal™ Hydraulic Reduction Sleeves are designed for high-precision clamping of straight cylindrical cutting tool shanks. The self-sealing design enables efficient use of through-coolant cutting tools when the cutting tool shank completely engages the full gripping length of the sleeve.
Designed for Precision, Stability, and Efficiency- Accelerated feed rates offer increased productivity
- Four-wall pocket provides insert stability
- One-piece design with slot configuration to seal coolant
- Through coolant standard for improved tool life, hole finish, and chip removal
- Cutting tool must be cylindrical and have a through hole when using coolant
- Units Supported: Metric with Inch Bores
- Adapter Style: Straight Shank
- Sleeve Series: HC20M
- Shank Outer Diameter (Metric): 20.000mm
- Shank Inner Diameter (Inch): 0.1875"
- Shank Inner Diameter (Metric): 4.763mm
- Gage Length (Metric): 4.000mm
- Overall Length (Metric): 54.000mm
#20mmOD14ID50mm
- Shank Inner Diameter (Inch): 0.250"
- Shank Inner Diameter (Metric): 6.350mm
#20mmOD516ID50mm
- Shank Inner Diameter (Inch): 0.3125"
- Shank Inner Diameter (Metric): 7.938mm
#20mmOD38ID50mm
- Shank Inner Diameter (Inch): 0.375"
- Shank Inner Diameter (Metric): 9.525mm
#20mmOD716ID50mm
- Shank Inner Diameter (Inch): 0.4375"
- Shank Inner Diameter (Metric): 11.113mm
#20mmOD12ID50mm
- Shank Inner Diameter (Inch): 0.500"
- Shank Inner Diameter (Metric): 12.700mm
#20mmOD916ID50mm
- Shank Inner Diameter (Inch): 0.5625"
- Shank Inner Diameter (Metric): 14.288mm
#20mmOD58ID50mm
- Shank Inner Diameter (Inch): 0.625"
- Shank Inner Diameter (Metric): 15.875mm
#32mmOD12ID60mm
- Sleeve Series: HC32M
- Shank Outer Diameter (Metric): 32.000mm
- Shank Length (Metric): 60.000mm
- Overall Length (Metric): 64.000mm
#32mmOD916ID60mm
#32mmOD58ID60mm
#32mmOD1116ID60mm
- Shank Inner Diameter (Inch): 0.6875"
- Shank Inner Diameter (Metric): 17.463mm
#32mmOD34ID60mm
- Shank Inner Diameter (Inch): 0.750"
- Shank Inner Diameter (Metric): 19.050mm
#32mmOD78ID60mm
- Shank Inner Diameter (Inch): 0.875"
- Shank Inner Diameter (Metric): 22.225mm
#32mmOD1ID60mm
- Shank Inner Diameter (Inch): 1.000"
- Shank Inner Diameter (Metric): 25.400mm
