HYDRAULIC CHUCK REDUCER SLEEVES 3/4" - 1 1/4" (INCH with METRIC BORES)
#34OD3mmID19685
Kennametal™ Hydraulic Reduction Sleeves are designed for high-precision clamping of straight cylindrical cutting tool shanks. The self-sealing design enables efficient use of through-coolant cutting tools when the cutting tool shank completely engages the full gripping length of the sleeve.
Designed for Precision, Stability, and Efficiency- Accelerated feed rates offer increased productivity
- Four-wall pocket provides insert stability
- One-piece design with slot configuration to seal coolant
- Through coolant standard for improved tool life, hole finish, and chip removal
- Cutting tool must be cylindrical and have a through hole when using coolant
- Units Supported: Inch with Metric Bores
- Adapter Style: Straight Shank
- Sleeve Series: HC750
- Shank Outer Diameter: 0.750"
- Shank Inner Diameter (Inch): 0.1181"
- Shank Inner Diameter (Metric): 3.000mm
- Shank Length: 1.9685"
- Gage Length: 0.1569"
- Overall Length: 2.126"
#34OD4mmID19685
- Shank Inner Diameter (Inch): 0.1575"
- Shank Inner Diameter (Metric): 4.000mm
#34OD5mmID19685
- Shank Inner Diameter (Inch): 0.1969"
- Shank Inner Diameter (Metric): 5.000mm
#34OD6mmID19685
- Shank Inner Diameter (Inch): 0.2362"
- Shank Inner Diameter (Metric): 6.000mm
#34OD8mmID19685
- Shank Inner Diameter (Inch): 0.315"
- Shank Inner Diameter (Metric): 8.000mm
#34OD10mmID19685
- Shank Inner Diameter (Inch): 0.3937"
- Shank Inner Diameter (Metric): 10.000mm
#34OD12mmID19685
- Shank Inner Diameter (Inch): 0.4724"
- Shank Inner Diameter (Metric): 12.000mm
#34OD14mmID19685
- Shank Inner Diameter (Inch): 0.5512"
- Shank Inner Diameter (Metric): 14.000mm
#34OD16mmID19685
- Shank Inner Diameter (Inch): 0.6299"
- Shank Inner Diameter (Metric): 16.000mm
#114OD18mmID23622
- Sleeve Series: HC1250
- Shank Outer Diameter: 1.250"
- Shank Inner Diameter (Inch): 0.7087"
- Shank Inner Diameter (Metric): 18.000mm
- Shank Length: 2.3622"
- Gage Length: 0.1575"
- Overall Length: 2.5197"
#114OD20mmID23622
- Shank Inner Diameter (Inch): 0.7874"
- Shank Inner Diameter (Metric): 20.000mm
#114OD25mmID23622
- Shank Inner Diameter (Inch): 0.9843"
- Shank Inner Diameter (Metric): 25.000mm
