Flat rate shipping applied at checkout. If actual rate varies, the final order amount will be adjusted.
Compact Oil and Chip Separator Sump Vacuum Frog PUMP
The FROG: Oil and Swarf Vacuum Solution
The FROG, part of the OIL line, is designed to efficiently vacuum and separate oil and swarf from CNC machine tanks. This vacuum cleaner enhances cleaning operations and allows for the reuse of oil lubricants and coolants. Depureco's "reverse flow" system for liquid drainage eliminates the need for additional maintenance and reduces the risk of pump clogging during liquid transfer.
Key Features:
- Powerful Suction: Two parallel-operating motors ensure optimal speed.
- Efficient Separation: 34-gallon bin with a quick-release metal basket for separating solids and liquids.
- Effective Filtration: 150-micron filter for enhanced swarf filtration.
- Safety: Electrical level indicator stops airflow at maximum capacity to prevent overflow.
- Convenient Accessories: Comes with a comprehensive oil accessories kit designed for vacuuming CNC machines.
Includes:
- Super Heavy Duty Accessory Kit for Oil, Coolant, and Metal Chips
Cleaning Kit Info
Vacuum Accessory Kit for Oil and Swarf
Our Vacuum Accessory Kit for oil and swarf is designed to complement your industrial vacuum cleaner, enhancing its performance in CNC machine maintenance. This comprehensive kit ensures efficient handling of oil, lubricants, coolants, metal shavings, and swarf, providing a seamless cleaning experience.
Key Components:
- Durable Hoses: High-quality, flexible hoses designed to withstand oil and metal debris, ensuring longevity and reliability.
- Precision Nozzles: Various nozzles for targeted suction, optimized for different surfaces and debris types.
- Heavy-Duty Brushes: Sturdy brushes for scrubbing and loosening swarf and metal shavings from machine surfaces.
- Quick-Connect Couplings: Easy-to-use couplings for fast attachment and detachment, streamlining the cleaning process.
- Accessory Basket: Convenient basket to organize and store all accessories, keeping them within easy reach.
- Hose Holder Hooks: Two robust hooks to neatly store hoses when not in use, maintaining a tidy workspace.
Benefits:
- Enhanced Efficiency: Streamlines the cleaning and maintenance of CNC machines, reducing downtime.
- Improved Performance: Ensures optimal operation of your vacuum cleaner by providing the right tools for the job.
- User-Friendly Design: Easy-to-use components designed for quick setup and convenient storage.
- Versatility: Suitable for a wide range of cleaning tasks, from oil and coolant spills to metal debris removal.
Feature Highlights
Switches
The Frog features intuitive switches that allow operators to control suction and drainage with ease. These durable controls are built for reliability in demanding shop environments, ensuring seamless operation during heavy-duty applications.
Hose
Equipped with a reinforced, oil-resistant hose, the Frog ensures uninterrupted operation by efficiently handling oil, coolants, and swarf. The high-flexibility design minimizes kinking while maintaining robust suction performance.
Wheels
Engineered for mobility, the Frog's industrial-grade wheels provide smooth, stable movement across any shop floor. The sturdy design prevents tipping and enhances maneuverability, even when the 34-gallon bin is at capacity.
Pump
The Frog's integrated reverse-flow pump streamlines liquid drainage, eliminating clogs and additional maintenance. This advanced system enables efficient oil and coolant reuse, reducing waste and downtime in your CNC shop.
