EMCO EMCOMILL 1200 3-Axis CNC Machining Center
Compact and Versatile 3-Axis Machining Center
The EMCO EMCOMILL 1200 is a precision 3-axis machining center designed for flexible shop-floor production. Its compact footprint and rigid construction support a wide range of milling applications, while the fixed table handles workpieces up to 3,307 lb (1,500 kg) with excellent stability.
An optimized welded steel machine bed and cast-iron linear axes provide long-term rigidity and accuracy. Available with Siemens 828D ShopMill or Heidenhain TNC 620 controls, and equipped with tool magazines up to 60 tools and rapid traverse speeds up to 98 ft/min (30 m/min), the EMCOMILL 1200 is built for reliable, efficient daily production.
Country of Origin: Austria
Customize Your CNC
BEYOND STANDARD
The EMCO EMCOMILL 1200 is a robust 3-axis machining center engineered for versatility and precision. With a large 1,500 kg table load capacity, high-rigidity cast components, and rapid traverse speeds of up to 30 m/min, it ensures smooth and efficient operation. Powered by Siemens or Heidenhain controls, this machine is built for long-term reliability and performance in demanding milling applications.
SPEED MEETS PRECISION
The EMCO EMCOMILL 1200 delivers powerful cutting capabilities with a main spindle speed of up to 12,000 rpm and 73.8 ft-lb (100 Nm) of torque, ensuring smooth performance on tough materials. An optional motor spindle with 15,000 rpm provides even greater speed for high-precision milling. With rapid traverse rates of 1,181 in/min (30 m/min) and acceleration up to 9.8 ft/s² (3 m/s²), the ECOMILL 1200 is engineered for fast cycle times and optimized efficiency in every machining application.
47.2" / 24.0" / 19.7" (1200 mm / 610 mm / 500 mm)
9.8 ft/s² (3 m/s²)
0.0004" (10 µm) / 0.00016" (4 µm)
Why Choose EMCO?
Precision engineered. Performance delivered.
EMCO develops flexible, high-performance machining systems built for industries like aerospace, automotive, and general manufacturing.
Every EMCO machine is designed and manufactured in-house, ensuring the highest level of quality, precision, and technological innovation.
Designed for durability and efficiency, EMCO machines deliver stable performance in demanding, multi-shift environments.
From installation to maintenance and upgrades, EMCO provides full-service support to maximize uptime and productivity.
With worldwide manufacturing and service hubs, EMCO delivers reliable solutions and expert support wherever you operate.
